Results 1 to 9 of 9
Thread: Klixon hell
    Scotland
    312
    12
    Klixon hell
    HELLO!
    I am having a bad day.
    I have a faulty Klixon for a Unidad Hermetica GL99AA R134a which I would like to replace for a new one.
    I've called several suppliers who either can't identify the Klixon form the numbers on it or who are asking for the compressor details or unit details, none of them can help so far.
    Does anyone know of a good Klixon supplier or who can recommend a suitable alternative or better way of replacing them, compressor running current is about 2A, I just need something that will do the job.
    Thank you.
    Somerset
    64
    4,586
    Re: Klixon hell
    Hi Contactor.
    You are having a rough time up your way with winds also eh!
    Anyway, a quick search has thrown up this which lists alternative comps.
    http://www.europart.co.uk/s.nl/it.A/id.7669/.f
    I will try and dig deeper to find maybe a suitable Klixon supplier.
    Dug a little deeper and this may help. From UH's site in spain it appears they are electrolux elswhere?
    http://galcontrol.ios.st/IOS/Users/g...troluxr134.pdf
    Scotland
    312
    12
    Re: Klixon hell
    Thanks Grizzly, I've bought a universal relay in the interests of remaining sane (and saving time)!
    Sep 2003
    ISRAEL
    66
    4,152
    38
    Re: Klixon hell
    You can let the compressor run for sometimes without the klixon, nothing should happened.
    Best thing is to protect the compressor with a miniature circuit breaker rated just above the compressor currant draw, that will give you time to get the klixon you need and the compressor will run protected.
    Auckland
    68
    3,362
    32
    Re: Klixon hell
    I agree with chemi, but would add that c/b be motor rated, or use a motor rated HRC fuse.
    Oct 2003
    56
    5,519
    28
    Re: Klixon hell
    Small resetable motor current realys are availbale very cheap at Farnell-in-one. They deliver mostly for free within 24 hours.
    GL99 is indeed an Electrolux compressor like Grizzly said. If you should live closer, I should say, you can have one from me for a coffee.
    But I do the same as you did if Idon't have the right one in stock (i have at least 60 to 80 relays, clixons and cap's in stock): buying an universal one.
    Split Croatia
    6,108
    7
    30
    Re: Klixon hell
    That compresorr has RSIR motor. You could use PTC instead of klixon.
    http://www.sparesrus.biz/ol-catlg/danfoss-start-01.htm
    Oct 2003
    56
    5,519
    28
    Re: Klixon hell
    This Danfoss clixon doesn't fit upsde down on an Electrolux Nike
    Jun 2010
    Yorkshire
    520
    14
    Re: Klixon hell
    What about a button stat say with a rating of about 120 deg, banded around the pot outside the terminal cover as a temporary fix?
    Training may be finished but experience is never complete.
