Thread: password Eliwell ID961
29-12-2011, 10:50 PM #1
Hi, new here... hope to find some help and advice
how can I disable password on Eliwell ID 961... Password is set to 16 but I want to disable it so that I don't have to enter it each time I go back... I can't find it anywhere here on forum, also googled it, but can't find the way to disable the pw.
Help pleasee Kind of complicated device for a woman
29-12-2011, 11:19 PM #2
Re: password Eliwell ID961
Last edited by install monkey; 29-12-2011 at 11:24 PM. Reason: pasted wrong parameter
29-12-2011, 11:21 PM #3
Hi and welcome.
If your controller is an ID961 and you can adjust parameters then select PA1 and set it to 0 (zero).
Instructions...
http://www.hawco.co.uk/userfiles/MediaLibrary/ID961ENGTEC.pdf
If you have an ID961LX then you have a PA1 and PA2 to play with...
Instructions...
http://www.hawco.co.uk/userfiles/Med...X-eng42002.pdfLast edited by Brian_UK; 29-12-2011 at 11:24 PM.
30-12-2011, 01:49 AM #4
From memory most elliwell default access codes are 220, unless some one has changed it.
30-12-2011, 05:52 PM #5
IM
Are those your daughters you are trying to marry off??
al
all repped out and nowhere to go....Mostly found in the southern part of this green and pleasant land.
30-12-2011, 05:55 PM #6
