Results 1 to 10 of 10
26-12-2011, 02:00 PM #1
Daewoo fridge freezer - fridge not chilling
Hello, not sure if anybody can help.
Our Daewoo FRN-U201A is only about one year old.
For several weeks now the fridge has not been chilling (feels like hardly at all) and we did have problems with the top of the freezer but since removing the rear bottom panel and hoovering the accumulated dust it seemed to improve.
Have tried; switching off over night & short periods to reset it, hoovered the dust from the back grill. Apart from that not sure what else to try.
Thanks in advance!
26-12-2011, 04:46 PM #2
Re: Daewoo fridge freezer - fridge not chilling
mike check ur e mail
26-12-2011, 07:21 PM #3
Thanks install monkey, however that was way too technical for me I'm afraid.
Unless there is an easier way to determine where the fault lays I will need to call somebody out. I meant to also mention there are clunking sounds occasionally coming from the machine also. I'm sure this does not help.
Cheers and I did appreciate the email!
26-12-2011, 07:35 PM #4
1. How to start
1) Press FRZ.TEMP button 5 times while pressing
REF.TEMP button at the same time.
2. How to stop
1) Push FRZ.TEMP button 1 time.
2) It stops automatically in 4 minutes from the start.
3. All the error codes are reset if they turn to be normal.
4. Error display
if yoINPUT CONTROL OBJECT
CONTENTS REMARKS
Temperature Control Buttons Lamp LED of Inner control
(Full down mode and forced defrost mode are displayed while pressing
REF.TEMP button at the error display mode)
REF. LED Forced defrost mode for A/S 1 is on and off (twice)
Full Down mode REF. LED 1 is on
EEPROM : defective REF. LED 1 is on and off
Return after defrosting : defective REF. LED 2 is on and off
Cycle : defective REF. LED 3 is on and off
F-Door Switch : defective REF. LED 5 is on and off
R-Door Switch : defective FRZ. LED 1 is on and off
D-sensor : open (Lo), short (Hi) FRZ. LED 2 is on and off
RT-sensor : open (Lo), short (Hi) FRZ. LED 3 is on and off
R-sensor : open (Lo), short (Hi) FRZ. LED 4 is on and off
F-sensor : open (Lo), short (Hi) FRZ. LED 5 is on and off
if its like mine without the water dispenser and the ice maker just 2 buttons in the fridge
check u can hear the fan running when u push the door switch with the door open
the clunk noise is normally when it just goes on defrost,and the defrost heater is warming up
26-12-2011, 07:52 PM #5
install monkey doing my job for me now
26-12-2011, 08:00 PM #6
26-12-2011, 08:27 PM #7
should of brought a decent one then lol
if i rate this thread will it give u power rep install?
26-12-2011, 08:31 PM #8
i wanted the panasonic £1100 quid beastie with led's, inverter compressor-but u know what women are like when they go shopping-if they dont choose it then theyll take it back for a refund and get the 1 they wanted
is bothyman local to norfolk?
26-12-2011, 09:50 PM #9
26-12-2011, 11:22 PM #10
unfortunatly if i pimped a fridge to chill beer in minutes-id need a non leaking ice builder and and i dont think the boss would be too happy that her microwave currys are soggy!!!! also where could i keep my pizza's!!!
