Results 1 to 14 of 14
    Aug 2009
    Serbia
    49
    13
    SAB 8-180 and VMY 432
    Hello coleagues
    I am preparing reconstruction of old industrial plant and I am planning to use three existing compressors:
    SABROE SCREW PACKAGE VMY 432 MK2, for low stage, 250 kW EM
    SABROE PISTON PACKAGE SMC 8-180, for high stage, 200 kW motor, 750 rpm
    SABROE PISTON PACKAGE SMC 8-180, for low stage, 90 kW motor
    Does anyone know capacities for these compressors?
    Low stage means -40/-10C. High stage means -10/+35C
    Nov 2009
    france
    64
    223
    Re: SAB 8-180 and VMY 432
    hi Bezar,
    I could send you something next week but you must give some more informations:
    - refrigerant? NH3!
    - I know VMY 425, 436 Mk2, 437 but not 432. are you sure of these digits. if it is 436 there is a letter behind H, L,M...
    regards
    Aug 2009
    Serbia
    49
    13
    Hi Cricri
    Thanks for your reply.
    Yes it is NH3, I thought it is obvious but it was my mistake not to mention.
    Regarding screw compressor, yes it is 436 MK2, again my mistake.
    Thanks in advance
    Nov 2009
    france
    64
    223
    OK, we'll see that next week
    Dec 2008
    Portugal
    48
    1,020
    Bezar,
    Regarding the piston compressors I can help you immediately. Concerning the VMY since it's a even more old out-phased compressor I would have to check the old libraries (and I'm on vacations)...if cricri can't help you I help you later.
    About the SMC 8-180, it is a MK1 if it was a MK2 it would be a SMC188...please check. The head covers are rounded on the MK1.
    The MK1 gives about 90% of the MK2 capacity. The swept volume of the MK1 is lower.
    Right now I just have information about the MK2 » SMC188:
    -10șC/+35șC (with non pressure losses and non superheated) » cooling capacity 763 kW, shaft power required 197 kW.
    If it is SMC188 MK2 the 200 kW motor will be short. If it is SMC8-180 so it looks okay...even so if the suction and discharge pressure increase enough the motor could the overloaded.
    -40șC/-10șC (with non pressure losses and non superheated) » cooling capacity 216 kW, shaft power required 57 kW.
    Somerset
    69
    4,697
    Hello Bezar.
    Hopefully some of the attached will be of use to you?
    Aug 2009
    Serbia
    49
    13
    Thnks for info on pistons. I appriciate it. Do you have any ide why would they mount 90 kW motor on low stage SMC8-180 if the shaft power is so low?
    Regarding HS SMC, it is 8-180
    Please send VMY information when you get back from vacation, and have a some good time, wherever you are.
    Aug 2009
    Serbia
    49
    13
    Hello Bezar.
    Yes, it is helpful information, although it does not contain capacity data. But anyway, it is helpful regarding compressor working area data.
    Dec 2008
    Portugal
    48
    1,020
    Still not containing the refrigeration capacity you can have some good idea of the capacity based on the swept volume compared with the capacity of a compressor which you know its own capacity.
    Dec 2008
    Portugal
    48
    1,020
    It Could be a case of a blast freezing tunnel (on its star up the suction pressure can well stay a while on -25șC) or just cold stores (evaporating temperatures about -30șC...and on some moments can rise a little the suction pressure). Also the LP discharge pressure can be somewhat about -5șC in some peaks.
    In any these common cases the electric motor shall be 90 kW to run nice without thermal overload danger.
    Quote Originally Posted by bezar View Post
    Dec 2008
    Portugal
    48
    1,020
    I'm still in vacations but I did a search to AERZEN who is the manufacturer of the VMY (at many years ago the firsts screw weren't SABROE).
    In the file I sent you I think you will find the info you want.
    Attached Files Attached Files
    Nov 2009
    france
    64
    223
    Hi Bezar, you can check your mail box
    Aug 2009
    Serbia
    49
    13
    Hey guys thank a lot for your help. Especially to cricri and Sandro Baptista.
    Dec 2008
    Portugal
    48
    1,020
    You don't need to thank. Happy New Year 2012 to you Bezar.
