Results 1 to 8 of 8
    Dec 2011
    4
    Ariston integrated fridge freezer noisy and hot
    I have an Ariston integrated fridge freezer which is about 6 years old (was already there when I moved in in 2007). 2 days ago, I noticed that it started to make continuous noise rather than the intermittent noise like most fridges do. In addition, I noticed that the top part of the outside of the freezer was hot to touch, although everything inside the fridge and freezer is still working well. There are no leaks, and the draining hole in the fridge is draining.
    I am worried about it, and not sure what to do, please advise.
    Thank you
    Feb 2010
    47
    14
    Re: Ariston integrated fridge freezer noisy and hot
    When working properly, the thermostat turns the compressor on and off. Once the thermostat turns the compressor on, it will run until the temperature inside the refrigerator is lower than the setting of the thermostat.
    Make sure that the refrigerator has enough air clearance on all sides. Refrigerators with a condenser coil grid on the back of them need room to radiate the heat away from the coils.
    Verify that the door light switch is working properly. Push the switch with your finger to verify the light is turning off. If the light stays on, it will actually warm the interior of the refrigerator. Fix or replace the switch if needed.
    If the compressor is not shutting off when the temperature inside the refrigerator is cold enough, you may have a faulty thermostat.
    If your thermostat is working properly, there’s a chance that you have low levels of refrigerant in the sealed system. If this is where the symptoms lead you, you need to contact a professional appliance repair person.
    Regards Paul.
    Feb 2010
    47
    14
    Oh ment to say check the setting on the thermostat is not too high.
    Paul.
    Dec 2011
    4
    Hi Paul
    Thanks for the help. My Ariston fridge is an integrated fridge freezer, so I can't take it out to look at the back. Also, is the thermostat the dial with numbers inside? To check if it's working, is it simply to turn it up or down and 'feel' if the fridge is cold or not??
    Would emptying the fridge and defrosting the fridge freezer possibly may help sort the problem?
    Thank you
    Sep 2008
    Letsby Avenue
    359
    Model number please,pull out salad draws and its usually on the side wall somewhere.
    BG
    “Life is like riding a bicycle. To keep your balance you must keep moving” Einstein
    Dec 2011
    4
    The model is Ariston BC 312 AI UK
    Thanks!
    Sep 2008
    Letsby Avenue
    359
    Machine needs to come out to ensure good ventilation,ie not blocked although does sound like poor compressor performance or low refigerant.If the thermostat is mid range 3-4 it should b cycling on and off.
    Shopping time or a techie visit.
    BG
    Dec 2011
    4
    Thank you. If it's the compressor or low refridgerant, can it be fixable by an engineer and how much would the cost approximately? Is it worth repairing or better to buy a new fridge which will have to be fitted as it's integrated.
    Thanks!
