Results 1 to 9 of 9
    Jan 2009
    Australia
    108
    23XL Howden Compressor
    Hi guys,
    I've got a rebuild to do on a Howden screw compressor from a 23XL chiller on R22. I could do with a manual. Anyone got one I could use?
    Jan 2009
    Australia
    108
    Re: 23XL Howden Compressor
    By the way, it's a Frame 4 model - 1.25MWr. It's a good size. Weighs about a tonne and a half. I think there's some fancy tools required to look after these as they are coming apart. Any info or links to info on offer will be most gratefully accepted.
    3,359
    Scramjetman
    The only fancy tools is a 10tonne porta power which I'm sure you can hire.
    If its more than 15 yrs old or so you may require a thrust bearing locknut spanner.
    Have you ever worked on a screw before?
    What machine is it WRV255 ?
    Jan 2009
    Australia
    108
    Not this size. 350 tons. Compressor is 13 year old. I've got all the service bulletins for it and they give us a fair bit of info, but we could do with a teardown and reassemble procedure. It will just speed things up for us. Portapower's no problem.
    Apr 2010
    45
    78
    15
    I'm not dissing your skill levels but screw comps run very high tolerances. If you dont have the experience i wouldn't attempt it. We make most of our own tools as we go such as bearing pullers. remember bearing and gasket kits are not cheap, use the correct tools and measure twice.
    Jan 2009
    Australia
    108
    Thanks Savoc. I've got a pretty savvy fitter on the job. We've got it apart ok. Motor's off and slide valve assembly is off. Just need a bit of guidance in getting the rotor assembly apart now if anyone can assist. Its got a whole stack of bearings in there and the client wants to replace them all. A take-apart manual or service bulletin on the rotor assembly would be good.
    Jan 2009
    Australia
    108
    My apologies too - when we got it into the shop, it turned out to be an Ingersoll Rand compressor - not a Howden. It's got the thermistor box on the top which is a give away on the manufacturer.
    3,359
    Can you post a picture or something, as I think it might be a Frick compreesor.
    Ingersll Rand use them in refrigeration from what I can gather.
    Jan 2009
    Australia
    108
    Well, the latest is we got it apart comfortably. To do it, we made up a toolkit for it and it worked well. Thanks for your input.
