Thread: Polar Ice Machine T316 problem
20-11-2011, 03:36 PM #1
Hi, when the black tray goes up the water switches on for a few seconds until the tray is only 1/4 full at best and then it begins to freeze, so only makes very small ice cubes. If I turn the machine off and then on, it will fill with water to the top as it should, but once this ice drops it goes back to only filling 1/4 full. Any help will be much appreciated, before I have to fork out for a new one.
20-11-2011, 05:46 PM #2
Re: Polar Ice Machine T316 problem
on initial start up the ice machine energises the solonoid for longer-to flush the water circuit,then on each cycle it isnt as long,have u checked the inlet filer -shut the water off at the local isolation,remove the hose and check inside the water solonoid for a removable gauze that may need cleaning,also is the water pressure sufficient?
20-11-2011, 05:53 PM #3
justin u have mail
20-11-2011, 07:40 PM #4
The water level is controlled by the water level sensor its the white one on the left is the cubes its makeing very white by any chance rather than clear
14-02-2012, 10:20 PM #5
