    Dec 2011
    US
    48
    10
    3 way valve Hydronic heating coil N.O ?
    which side is the N.O side of 3 way valve for heating coil? at the inlet or outlet.
    and which side is N.O for cooling coil?
    any input,will thanks
    Auckland
    74
    3,357
    38
    Re: 3 way valve Hydronic heating coil N.O ?
    The bottom port of 3 port is the bypass
    Dec 2010
    Toronto, Canada
    1,454
    which brand. they are not all the same
    Dec 2011
    US
    48
    10
    its a danfoss
    Dec 2010
    Toronto, Canada
    1,454
    If it is an Danfoss ESBE, then it doesn't matter as long as the input is the middle one. If it is a thermostatic then the inputs are H on left, C at bottom and mix on the right. I use them all the time.
