17-12-2011, 05:49 PM #1
Hoover VCN6185 - Fridge Freezing Up Checklist.
Hi folks,
I have just purchased a Hoover VCN6185 for very little to store my kegs of home brew....
The fridge compartment is freezing up.
I hoping its an easy fix so I thought I could as you guys to check my 'checklist'
1. Check the drain.
2. Check the re circ fans are blowing
3. Door seals.
4. Thermostat. Are there 2? Fridge and freezer?
Any helps would be great.
LeeLast edited by Brian_UK; 18-12-2011 at 12:13 AM. Reason: Thread moved to correct section.
17-12-2011, 05:54 PM #2
Re: Hoover VCN6185 - Fridge Freezing Up Checklist.
A link to the fridge.
http://www.amazon.co.uk/Hoover-VCN61.../dp/B003TYBKX0
21-12-2011, 11:03 PM #3
replace the thermostat
23-12-2011, 09:26 AM #4
This model has a fridge sensor/thermistor,embedded in the insulation not the standard thermostat.Resistance needs checking at pcb/control board terminals to establish if it is faulty,it means cutting away ome of the insulation at the rear to access it.Available from partmaster/espares/ukwhitegoods,instructions come with it but it is a pain to do.Cheapo made by Candy,nuff said!
Is it worth it?“Life is like riding a bicycle. To keep your balance you must keep moving” Einstein
