Results 1 to 2 of 2
    Dec 2011
    Australia
    2
    Fujitsu ASTA24LCC how to replace fan
    G'Day, the indoor fan unit needs replacing, I've been trying to work out how to get the fan out, but with no luck. I tried to take the plastic part with the PCB out, loosened all the screws, also the same with the bottom part, the same result...
    Would anyone know how to take this fan out, or where to get a service manual for this unit?
    Oct 2011
    new zealand
    23
    Re: Fujitsu ASTA24LCC how to replace fan
    drop the drain tray out peter. fujitsu are shockers for the fans packing up
Tags for this Thread
