Results 1 to 2 of 2
    Dec 2011
    United States
    40
    8
    How to determine cooling capacty
    How do I determine the cooling capacity needed for a specific application?
    I know the item I want to cool, it's two large bottles of water. Refrigerant is R-143a. The temperature I want in the fridge is 38F. So, based on the 3 variables of ambient temperature, thermal load and fridge temperature how do I determine the cooling capacity I need in Watts?
    Is the thermal load simply Q=m*cp*deltaT of the bottles of water?
    I know that to size a compressor, the cooling capacity is given for a specific temperature at the evaporator. I know that it needs to be less than the temperature I want in the cooling cabinet (38F), but how much less?
    Dec 2011
    United States
    40
    8
    Re: How to determine cooling capacty
    Is the calculation simply
    Cooling Capacity (W) = Qthermal load/desire pull down time - Qheat gain through walls
    where
    Qthermal load = m*cp*deltaT
    Qheat gain through walls = h*A*deltaT+k*A/d*deltaT
    This doesn't account for the decrease in ability to cool at high ambient temperatures, so I don't think it's correct. help please!
Tags for this Thread
