12-12-2011, 10:49 AM #1
Vac pump powered by an air compressor
Has anyone used a vac pump thats powered by air ? i bought one a fews days ago . waiting until it comes from eerm china .
http://www.ebay.com.au/itm/360351906...84.m1497.l2649
they say it pulls a full vacuum in 2mins ha. cant wait to put vaccy stat on it . are these just the same as a normal 2 stage pump or a little faster? or just crap waste of money?
12-12-2011, 01:20 PM #2
Re: Vac pump powered by an air compressor
These only go to 28.3 inches of Mercury.
Not low enough for professional use. A amateur at home might get away with it.
12-12-2011, 03:26 PM #3
Using compressed air as power supply increases the electricity consumption by 8 times.
Pneumatic systems are the highest power consuming.
12-12-2011, 06:48 PM #4
It`s a vacuum generator. It uses compressed air passing over an orifice to create a vacuum. They`re often used in the print industry to lift card into sheet fed presses. Horrendously inefficient. Whenever we come across them we advise replacement with a side channel vac pump or combined blower and vac pump, usually carbon vane to eliminate possible oil contamination.
13-12-2011, 06:39 AM #5
yeah i was going to send it back . i didnt read it correctly because i was on my phone .. cheap crap! .
