    Dec 2011
    Australia
    69
    7
    Vac pump powered by an air compressor
    Has anyone used a vac pump thats powered by air ? i bought one a fews days ago . waiting until it comes from eerm china .
    http://www.ebay.com.au/itm/360351906...84.m1497.l2649
    they say it pulls a full vacuum in 2mins ha. cant wait to put vaccy stat on it . are these just the same as a normal 2 stage pump or a little faster? or just crap waste of money?
    Jul 2006
    68
    735
    Re: Vac pump powered by an air compressor
    These only go to 28.3 inches of Mercury.
    Not low enough for professional use. A amateur at home might get away with it.
    Sep 2003
    ISRAEL
    66
    4,152
    38
    Using compressed air as power supply increases the electricity consumption by 8 times.
    Pneumatic systems are the highest power consuming.
    Sep 2008
    430
    14
    It`s a vacuum generator. It uses compressed air passing over an orifice to create a vacuum. They`re often used in the print industry to lift card into sheet fed presses. Horrendously inefficient. Whenever we come across them we advise replacement with a side channel vac pump or combined blower and vac pump, usually carbon vane to eliminate possible oil contamination.
    Dec 2011
    Australia
    69
    7
    yeah i was going to send it back . i didnt read it correctly because i was on my phone .. cheap crap! .
