Thread: Rules of Thumb?
    Dec 2011
    United States
    8
    Rules of Thumb?
    I have been designing consumer products for a long time, but I am currently on a project that requires understanding refrigeration - and I am way out of my depth (think Junior year thermo with one chapter on cycles). So any and all help is appreciated!
    The problem statement:
    Designa n appliance to cool 2 one-gallon bottles of water. Assume a typical refrigeration system with R-143a. The evaporator is directly coupled to the cooler walls, so there is no fan/blower to circulate the cold air.
    Are there rules of thumb for things like-
    Setting the temperature at the evaporator? I know it needs to be less than the temperature I want inside the cooler cabinet, but how much less?
    Leakage of heat from the environment to the cooler cabinet? I can calculate the heat transfer rate, but is there a typical margin that is used?
    Margin on the cooling capacity required by the system? If I can determined the Watts I need for the compressor, do I really specify a compressor that is 1.5x or 2x that for margin?
    Thanks!
    Oct 2007
    manchester
    43
    5,709
    Re: Rules of Thumb?
    Designa n appliance to cool 2 one-gallon bottles of water- but its already been designed,proved and patented, its called a fridge
    Dec 2011
    United States
    8
    Re: Rules of Thumb?
    @ install monkey.
    well yes, captain obvious strikes again! haha
    i guess, more specifically, an appliance that shaped and built to cool only the bottles. so like a small fridge, but with good cooling power.
    Oct 2007
    manchester
    43
    5,709
    Re: Rules of Thumb?
    http://www.hvacrinfo.com/loadcalcs.htm
    heatcraft engineering manual
    check out this manual
    yours captain monkey
    Aug 2009
    New Zealand
    2,556
    Re: Rules of Thumb?
    You will find that it is not the refrigeration that effects the speed of cooling, but the water! Your water needs to move!
Tags for this Thread
