    Dec 2011
    India
    4
    MCHX - ALuminium ~ Aluminium joint - Leaks
    Gentlemen,
    I am seeking for the solution on the above subject.
    Problem :
    We are using MCHX condenser for our Split air conditioners, now we are facing problem of leakage in Aluminium - Aluminium joints (with adaptor). I am attaching the images for the same.
    Kindly help me out with your expertise.
    Thanking you
    Ashok
    India
    Aug 2010
    INDIA
    38
    5
    Re: MCHX - ALuminium ~ Aluminium joint - Leaks
    There should be enough contact area to braze any joint then only you can ensure that your brazing has got enough strength.
    Dec 2011
    India
    4
    We are ensuring enough contact area, but we are observing lot of vibration in the discharge line & I guess because of this, the joint is getting cracked. we have provided discharge loops & still cant get the results.
    Compressor used - Rotary Comp
    Pipe size 3/8"
Tags for this Thread
