Results 1 to 9 of 9
Thread: r-262?
    Dec 2011
    37
    3
    r-262?
    I found some refrigerant tanks at my work today labeled r-262. i tried searching for what this was online and could only find that its some kind of chloroflouropropane. Anyone seen this before and if they have what was it used for and what am i dealing with. thanks.
    Oct 2007
    manchester
    5,639
    45
    Re: r-262?
    R-&10000000000000262000000262 Chlorodifluoropropane C3H5F2Cl 134190-53-7 &100000000000000000110000.002-0.02[5]
    • Ethane, chlorodifluoro-
    • Molecular Formula:C2H3 Cl F2
    • CAS No.:25497-29-4
    • Synonyms:Chlorodifluoroethane;Difluorochloroethane; Difluoromonochloroethane; Monochlorodifluoroethane; R 142
    • Molecular Weight:0
    • Density:1.193g/cm3
    • Boiling Point:31°Cat760mmHg
    • Flash Point:°C
    • Safety:RIDADR 1956HazardClass 2.2
    • Molecular Structure:
      C2H3 Cl F2
    Dec 2011
    37
    3
    Re: r-262?
    that helps but, i was mostly looking for what it was used for
    Sep 2010
    23
    Re: r-262?
    I have never come across this beforee. Based on the molecule it is likely to be flammable, please be safe.
    Sep 2003
    ISRAEL
    72
    4,248
    Re: r-262?
    HCFC R-262 Chlorodifluoropropane C3H5F2Cl
    My guess is that it was made to replace r-22 or 502,
    Jun 2009
    Lusk , Dublin
    1,115
    Re: r-262?
    It's used as a catalyst for something or other in the petrochemical world .
    I'm afraid I can't elaborate as I could not be arsed reading all this .
    But feel free.
    http://www.uop.com/wp-content/uploads/2011/04/UOP-Reforming-Solutions-for-.Improved-Profits-Paper.pdf
    C
    heers
    Stu
    Tool's ? check ! Condom's ? check !
    11,025
    Re: r-262?
    Thanks for that link Stufus, says it all really, clear as mud....
    For these situations, UOP's primary CCR Platforming catalyst of choice is R-262, which contains a 20% higher platinum loading than in R-264. R-262 is recommended for some older generation CCR Platforming units and is typically also recommended when UOP catalyst is used in CCR reforming units designed by others. R-262 is also being used by several customers with relatively high sulfur levels in the feed to their reforming units.
    Jun 2009
    Lusk , Dublin
    1,115
    Re: r-262?
    Glad to be of assistance.
    Always ready and willing, but rarely able!
    Stu
    Dec 2011
    37
    3
    Re: r-262?
    yeah thanks guys...this helps a lot
