Results 1 to 8 of 8
Thread: Daikin KRP4A
07-12-2011, 10:01 AM #1
Daikin KRP4A
Hoping someone can help me out here
Wondering if someone can explain the Daikin product codes, specifically the wall controllers, FCU's & Condensing units?
I'm also trying to find out which Daikin ducted models are compatible with KRP4A interface module? can you determine this based off the controller or does it depend on the unit?
Any help would be greatly appreciated.
07-12-2011, 09:47 PM #2
Re: Daikin KRP4A
The Daikin Skyair products have a different communication protocol from the VRV systems.
The KRP4 is compatible with the Skyair comms and the KRP2 is compatible with the VRV comms.
The smaller Daikin splits (upto 6kW) have different protocols (KRP413A etc)
Why not send an e-mail to your local Daikin office - I'm sure that they would be able to help.
08-12-2011, 08:57 PM #3
Re: Daikin KRP4A
Thanks for the reply, i'm only really interested in the Daikin Ducted units not splits.
I spoke with Daikin & was advised that the card is compatible with all F, M & K series FCU's but i'm sure this must be also restricted by the age of the unit??
Can anyone explain the Daikin FCU product codes?
08-12-2011, 10:42 PM #4
Re: Daikin KRP4A
Can you post the full model number of your fan coil?
11-12-2011, 12:37 AM #5
Re: Daikin KRP4A
The KRP4 card can be connected to any fan coil which has P1P2 controller connections,
Sky Air ducted indoor units FBQ or FDQ (high static) or VRV ducted indoors FXSQ, FXMQ & FXDQ .
The card can not be connected split indoor units FDX/K ducted
11-12-2011, 09:54 PM #6
12-12-2011, 01:20 AM #7
Re: Daikin KRP4A
VRV Indoor Example FXSQ32P7V1:
F = Indoor
X = VRV
S = Indoor type (S standard ducted)
Q = Refrigerant type (410)
32 = Capacity
P7 = Series
V1 = Single phase 50Hz
Sky Air Example FBQ71C8V1
F = Indoor
B = Indoor type (standard ducted)
71 = Capacity
C8 = Series
13-12-2011, 11:35 AM #8
Re: Daikin KRP4A
WOW that's awesome, much appreciated.
So what about the current ducted system product range it's code is FDYQ
F = Indoor
D = ???????? if this was ducted wouldn't it be B as below?
Y = ????
Q = R410a
Sorry for the million questions, is there a list of all these somewhere that i'm missing??
Cheers for all your help
