Thread: Errecinque
    Aug 2009
    New Zealand
    2,554
    Errecinque
    Good'y lords, ladies
    has anybody used the Errecinque range of products.
    At present i just use cap tubes to connect to my pressure switches ect, nice and cheap, but these micro man made tubes look good, but are they reliable, do they leak, any problems.
    cheers in advance
    Mad
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Re: Errecinque
    Have to get us photo's or links Mad.
    Aug 2008
    55
    259
    Re: Errecinque
    I've used them, and like them. Had no issue's. Only negative.... if they are the type I use is you can loose the little copper washer that seals the joint.
    A bit of a bugger when it disappeared into the bilge of the boat I was working on....had to flare one up from copper tube, cut the flare off and then file it down.
    Aug 2009
    New Zealand
    2,554
    Re: Errecinque
    Dec 2010
    Toronto, Canada
    1,454
    Re: Errecinque
    Mad, Do you use them for main vapour lines or just small diameter stuff?
