Thread: Errecinque
01-12-2011, 02:53 AM #1
Errecinque
Good'y lords, ladies
has anybody used the Errecinque range of products.
At present i just use cap tubes to connect to my pressure switches ect, nice and cheap, but these micro man made tubes look good, but are they reliable, do they leak, any problems.
cheers in advance
Mad
01-12-2011, 07:03 AM #2
Re: Errecinque
Have to get us photo's or links Mad.
01-12-2011, 07:24 AM #3
Re: Errecinque
I've used them, and like them. Had no issue's. Only negative.... if they are the type I use is you can loose the little copper washer that seals the joint.
A bit of a bugger when it disappeared into the bilge of the boat I was working on....had to flare one up from copper tube, cut the flare off and then file it down.
01-12-2011, 08:00 AM #4
Re: Errecinque
Hi Mike,
Try this
http://www.errecinque.it/eng/default.htm
01-12-2011, 12:00 PM #5
Re: Errecinque
Mad, Do you use them for main vapour lines or just small diameter stuff?
