30-11-2011, 03:20 PM #1
Leaking liquid line under foundation 60' ; stop leak product fix?
Florida condo, unenclosed liquid line buried under slab under three units. Not practical to re-route up/around. I'm going to go with a hail mary stop leak solution fix rather than attempt to pull new line.
Anyone have experience with the stop leak fix or pulling un-enclosed line that far?
30-11-2011, 05:41 PM #2
Re: Leaking liquid line under foundation 60' ; stop leak product fix?
30-11-2011, 08:12 PM #3
If it is underground contact a company who has a ground boring machine, to put a plastic pipe underground that you can use to put the pipe in. This drills a hole and pulls the sleeve through without digging a trench, and is often used here under roads and culverts to not have to dig up a busy road and lay a pipe. Generally it pulls though a 5 inch diameter pipe.
