Thread: Heat Reclaim
25-11-2011, 10:13 PM #1
Heat Reclaim
Fellow Members,
We have to design a a heat reclaim tank with 160 liters of water
entering with a water temp.of 28 centigrade to be heated up to 75 degrees centigrade.
Heat will come from the compressor rack.Any drawing or sketch to be shared by fellow RE
members .
abet
25-11-2011, 11:12 PM #2
Re: Heat Reclaim
There's always Sporlan to help on these things...
http://www.sporlanonline.com/5-180_072010.pdf
Plus other things as well...
http://www.sporlanonline.com/literature.shtmlBrian - Newton Abbot, Devon, UK
25-11-2011, 11:21 PM #3
Re: Heat Reclaim
160L tank with walls made of dimple plate stainless steel, sized to cope with the flow of refrigerant and or bypass arangement.
Suitable pressure and safety valves and pressure vessels to stop dangerous pressures in the tank.
Drain plug for cleaning out scale etc.Mostly found in Oxfordshire, UK :)
25-11-2011, 11:30 PM #4
Re: Heat Reclaim
These are about the best I've seen, double walled storage tanks, capillary action claims a lot more heat than standard plate heat exchangers plus you have storage built in.
http://www.dk-kaelteanlagen.de/en/ht...age-tanks.html
alLast edited by al; 25-11-2011 at 11:31 PM. Reason: forgot linky
26-11-2011, 12:25 PM #5
Re: Heat Reclaim
Thank you very much for the reply and information,Brian,Monkey Spanners and Al.Hopefully other members on the bench will add additional info on fabrication of tank.
abet
