    May 2008
    Farnham
    47
    Production area cooling
    Hi folks
    I have been asked to refrigerate a game (ie meat) production area and are not to sure of what evaporator/s to specify. The required temp must be 6 to 10 degrees and the airflow must be gentle for the comfort of the staff working. additionaly the coolers must be roof mounted with side air flow, that is not blowing downwards.
    The internal height is 2.7m and the floor is 9.6m X 6.0m giving a volume of 156m/3
    Any suggestions regarding the specification and sizing would be most welcome. there will be up to 10 people working and electrical load from machinary and lighting will be in the order of 2kw.
    Many thanks
    Somerset
    69
    4,698
    Re: Production area cooling
    pick a evap manufacturer and talk to them.
    They will advise.
    You have a good manufacturer in Farnham already.
    Sep 2003
    ISRAEL
    72
    4,248
    Have a look at these fabric air ducts, if you can apply them, they meet the requirments you asked for.
    http://www.fabricair.com/uk/
    Dec 2010
    devon
    837
    try a dual discharge unit sits in the middle of the room and blows both ways several wholesalers do a low temp dual discharge unit with variable speed the last one we had i believe come out of heronhill
    Oct 2007
    manchester
    5,639
    45
    tip,get the evap coils treated with blygold or similar fin treatment,also ensure the light fittings are weather proof, also with horizontal airflow this reduces complaints of draughts, reducing airflow decreases capacity and thus requires more defrosts-staff can wear gloves if a 6deg enviroment is not to their liking
    3,856
    Done something similar with a twin fan Searle evap, had special fan gaurds that you fit a fabric sock on like the ones Chemi linked to that run the length of the room. They fit into a channel in the roof. Need a set to use and a set to wash.
    Or maybe a dual discharge cooler, depends on customers budget.
