Thread: Torch
    Dec 2008
    Brazil
    106
    Torch
    Could you guys compare acetylen x LPG torch: temperatures, advantages and disadvantages.
    Also about these portable MAPP gas torch and their limitations.
    Moises
    Aug 2007
    Sydney
    52
    1,083
    23
    Re: Torch
    Hi Acrisoft
    I have tried them all (nearly). But swear by the recent availability of Oxy & Mapp gas welding set - It weighs about less than 4 kGs and I have welded 1 3/8" pipe with it. For sweating 1 1/8" pipe I use the Oxy & Mapp set with an additional Mapp torch. The others are simply too heavy. They are all hot enough to weld copper with. The size is also a bonus. The kit costs less than AUD$400. I would only use the normal Oxy Acetylene on a big install with lots of welding. One advantage for the big heavy set is for welding a valve (4way, TEV, ball etc) where you need fast preheating so as not to damage the internals and a quick weld. There is more info on this new kit in this forum somewhere.
    Apr 2010
    45
    78
    15
    Re: Torch
    i heard that the oxy runs out very quick. Is this true?
    Dec 2010
    devon
    837
    Re: Torch
    if there is plenty of space the mapps are fine we carry the twin and single flue version but if you have a confined space or a bad bit ofcopper or anything larger than 13/8 stick to oxy you get a more lacal heat with oxy and you dont have to get the area so hot over such a wide area
    Aug 2007
    Sydney
    52
    1,083
    23
    Re: Torch
    Yes Savoc it uses two oxy to one mapp gas.
    Feb 2009
    telford
    2,092
    33
    Re: Torch
    oxy/mapp gas for me,i have used them all the mapp on its own is too widespread with its heat on a big install its different space limitations etc,some people use propane/oxy [everytime i use it outside a force nine gale comes from nowhere and lighting up is a little difficult.
