Results 1 to 11 of 11
Thread: Carrier 06ET265960 Compressor
22-11-2011, 07:16 AM #1
Can someone please inform how to connect this compressor for 380/3ph/50 hz.
There is continuity between 1-4-7, 2-5-8, 3-6-9.The compressor has nine power terminals.The winding are okay and Megger readings to ground shows infinity.Thanks in advance.
22-11-2011, 07:20 PM #2
Re: Carrier 06ET265960 Compressor
Maybe the attached will help?
There are 2 three phase options.
Part wind or D.O.L.
22-11-2011, 07:52 PM #3
does the compressor leads have 2 contactors and a tiny orange delay timer then wire as part wind, if 3 contactors then its star delta configuration
22-11-2011, 08:46 PM #4
nice post grizzly .
best regardsTHE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
22-11-2011, 08:52 PM #5
You have 9 wires coming out not connected to any terminals?
22-11-2011, 10:12 PM #6
Thanks Goshen!
Chemi on the drawing I have attached it shows a link across 4,5 and 6.
Whereas on another which is to large to post it shows 4,5 and 6 as thermistor terminals.
That should be easy to prove by metering them out.
Grizzly.Last edited by Grizzly; 22-11-2011 at 10:18 PM.
22-11-2011, 10:37 PM #7
Hi Grizzly,
a good post, the 9 terminals had me thinking. But being Carrier they would make them for any and every voltage option to standardize things.
22-11-2011, 11:25 PM #8
- Join Date
- Sep 2009
- Location
- Iran
- Age
- 66
- Posts
- 672
- Blog Entries
- 1
- Rep Power
- 19
for 380 V /3 phase /50 HZ
1-4-7 is a one phase you say R or L1
2-5-8 is a second phase say S or L2
3-6-9 is a 3ed phase say T or L3
25-11-2011, 01:31 AM #9
Hi Grizzly
Good bit of info, I have saved it in our Carrier file, like Magoo 9 terminals had me wondering as well, thank you.
Paul
25-11-2011, 06:49 AM #10
Hi Guys.
It would seem there is a info gap where these comps are concerned.
Here is a Pocket Manual link (Which I have posted before )
Check out pages 112 and 113, all will be revealed!
http://www.carlylecompressor.com/Fil...ver_LOWRES.pdf
If more detailed info is needed, you know where I am.
12-12-2011, 10:48 AM #11
Hi Grizzly,
Accept my belated thanks for the information. The compressor is now working okay. Thanks once again.
