    Nov 2011
    1
    Can someone help with integrated Fridge/Freezer problem?
    I don't know if anyone can help me. I moved into a new house a few months ago and it has an integrated fridge freezer in the kitchen.
    I don't know what make or model the fridge freezer is as it is not obvious.
    I am now having problems with it in that the fridge doesn't seem to be cooling properly. The freezer seems to be working ok, despite being a bit icy.
    Can anyone tell me first of all how to identify the make and model of the fridge freezer then I can come back to you with this info and see if the cooling issue can be resolved?
    Many thanks in advance
    Lins
    11,025
    Re: Can someone help with integrated Fridge/Freezer problem?
    There should be a manufacturers data plate somewhere on the inside of the machine. Normally in the fridge side as it doesn't get iced up.
    Jun 2009
    Lusk , Dublin
    1,115
    Hi Lins
    If you have veg drawers in the bottom pull them out , the plate is probably there.
    Stu
