Results 1 to 12 of 12
Thread: braided hose
09-11-2011, 09:17 PM #1
braided hose
Good morning everyone! regular time poster here and was wondering if anybody has used braided hose pipe on any install jobs and was wondering how they found it?
09-11-2011, 09:42 PM #2
Re: braided hose
priceless!
09-11-2011, 10:46 PM #3
Re: braided hose
Heard it's good for C02 not much use for nh3 though, found mine in HRP
09-11-2011, 10:51 PM #4
09-11-2011, 10:54 PM #5
Re: braided hose
i heard that u need to use unbraided hose for nh3 as braided fibres can get eroded and clog the system up,also unbraided is better for 0 to -40 range
09-11-2011, 11:36 PM #6
Re: braided hose
Makes perfect sense does that
10-11-2011, 01:26 PM #7
Re: braided hose
Never had a problem with it.
20-11-2011, 04:37 PM #8
Re: braided hose
Use it a lot, makes a great drain line, flexible and cheap - just find the nearest garden hose and a quick "trim" gives you whatever length you need.
On cars it tends to leak refrigerant a little over the years though.
20-11-2011, 05:05 PM #9
Re: braided hose
I use it for everything, can't afford copper
20-11-2011, 05:59 PM #10
Re: braided hose
it has no resale value and saves on vibration eliminators,you only need 6mm wall thickness insulation as polpypropylene has a better u value- so its cheaper on installs of small splits upto 5kw,and its user friendly
20-11-2011, 07:50 PM #11
Re: braided hose
they have used braided hose on the co2 cartridges on paintballing guns for years.
here is a link used by a german company for vehicle a/c
http://www.compressortech.co.uk/down...ann_report.pdfyour only as good as your last job
13-12-2011, 04:38 PM #12
Re: braided hose
In some instances, I have recommended changing out stainless tubing to braided hose in order to reduce vibration levels. Most recently, on a large Kobelco's oil injection pump which is driven off the outboard end of the rotor.
