Thread: installation
    May 2009
    india
    68
    28
    installation
    Dear Friends,
    At what height the liquid receiver to be installed when all plants (compressor,motor & chiller) are at floor level. I am ***** systems installer, and now I want to start installation
    of NH3 Systems. Can any body give me suggestions/data regarding NH3 systems installation and general elevation drawing data.
    please mail to: kartheekus@yahoo.com
    Jul 2005
    61
    68
    Re: installation
    There is no one correct answer. The receiver can be located at the same level or at a different level. When it is at a different level it is more often above the compressor(s) but it can be at a lower level. The condenser piping, the system feed and compressor oil cooling will all be factors in determining the best location for the receiver in a particular installation.
    Sep 2009
    Iran
    66
    672
    1
    Re: installation
    Mean thing you do and work right designing and piping
    - Check valve after compressor and pipe Slop to condenser and from condenser to receiver
    With equalizing pipe (between receiver and condenser)
    oil drain valve + sight glass+ safety valve for receiver
    oil cooler should be close as much as you can to compressor
