Results 1 to 14 of 14
    Somerset
    63
    4,529
    38
    Is the answer 6K or 2K?
    OK. Guys.
    Say we have a Suction Temperature of 4c and a SST of -2c.
    Mathematically the answer of 4 and -2 added together is 2
    However 4 to -2 is a 6c split.
    So which is the answer from a superheat perspective?
    Jul 2010
    NTH.QLD Australia
    55
    1,755
    26
    Re: Is the answer 6K or 2K?
    Grizzly, +4 and -2 =6. As in 0 to +4*c sensible heat, then add the -2 to 0*c as well as it is is also sensible heat.
    Sep 2009
    Iran
    463
    12
    +4 -(-2)= +4+2 = +6
    Nov 2006
    44
    704
    Either point crosses the 0 Datum hence it`s 6 k
    Jun 2009
    North East England
    35
    714
    13
    Since superheat Is ^t of sst and st then it's 6C
    Nov 2006
    44
    704
    OK. Guys.
    I now understand your question and will explain the thoery of the one you will know---- It -4 +2 = -2 so +6 being the dt = 4 sst = +2 which is 6 -4 square which is -2
    So the final figure is an dtla figure
    Oct 2011
    ireland
    29
    sorry lads. just looking to find out how to start a new post
    Nov 2006
    44
    704
    go to home select forum and then start new thread thats my method
    Ps good site you have found here
    Oct 2011
    ireland
    29
    cheers quality
    Oct 2011
    ireland
    29
    hey quality, home and forum are beside each other, went in both and cant see anywhere to start new thread
    Nov 2006
    44
    704
    You need to select a form to post in click the forum and I normaly find the post new thread at the boottom
    Oct 2001
    Nottingham UK
    5,090
    42
    Quote Originally Posted by brian connolly View Post
    Click on the 'FORUM' button at the top
    Scroll down until you find the correct section title, i.e. 'Fundamentals'
    Open the selected section and the 'New Thread' button is at the top
    I'm back on the Pale
    Apr 2005
    42
    13
    Hey Grizzly
    The superheat is 6.
    I look at it this way - forget + and - numbers and work as if they are all 1 increments on a rule and count the difference between the two points.
    Thats my story anyway.
    Somerset
    63
    4,529
    38
    OK. Guys "Hands Up"!
    I already knew the answer, only I watched a chap calculating a superheat value recently and he took the negative value away from the positive.
    When I pointed out the correct method (as everyone else on this post!).
    I though "what a good topic for the forum"!
    Sadly you are all to clever.
    Some interesting way of explaining all the same.
    Thanks Grizzly
