Results 1 to 40 of 40
Thread: vapour compression cycle
Threaded View
01-11-2011, 08:58 AM #24
Re: vapour compression cycle
hey corkman.
know what you mean. i would imagine if you were heating liquid in a closed system (ie pressure cooker) once you start to heat the water the pressure would increase due to expansion. i would also imagine that frank presumed this was obvious and was only referring to pressure changes when the liquid was becoming a vapour and afterwards???????? maybe
