Thread: Water Cooler
    Aug 2011
    Malaysia
    29
    8
    Water Cooler
    Can a water cooler use both function in a refrigeration cycle, which i want to use it to boil water and making cool water?
    Mar 2008
    219
    14
    Re: Water Cooler
    Quote Originally Posted by Sunnyiq View Post
    The answer is no, the discharge temperature will be well below the boiling point of water, also electrical elements for water heating are very inexpensive.
    An electric kettle rated at 3KW can be purchased in the UK for less the 15.00 so I think in your part of the world it would be the same or less.
    Location, United Kingdom
    Oct 2003
    56
    5,519
    28
    Re: Water Cooler
    YOu only can use it to col and to heat water to...let's say 60C.
    Oct 2009
    Pietermaritzburg
    35
    40
    Re: Water Cooler
    alot of water coolers that heat and cool, have a seperate heating water tank, with elements
