    Oct 2011
    antalya
    5
    copeland scroll compressor Nomenclature system
    Hi, i need copeland scroll compressors Nomenclature system. For example i looked scroll compressor model in the emerson climate website for ZB15KCE-TFD and ZB15KCE-TFD . In this codes What is meaning of 'C' and 'Q'. What is the system of identification. I looked website of emerson but i didn't found 'C' and 'Q' explanation. İt' s only written model variation. What is the Model variaton system. Can someone help me? I have to learn this classification.
    Jan 2008
    Kent UK
    49
    514
    Re: copeland scroll compressor Nomenclature system
    Copeland Scroll refrigeration compressors (such as ZBxxKA-PFV) are designated by a "Z" in the first position of the model number. The second position determines the application range (B = high/medium temperature, S = medium temperature, F = low temperature). The third and fourth positions represent the first two digits of the capacity of the compressor at its standard rating conditions and the fifth position gives the multiplier for the capacity (C = 100, K = 1,000, and M = 10,000). The sixth position designates the compressor's model generation. If there is a seventh position before the dash prior to the electrical designation, it will be an E (Polyol Ester oil) or an L (shipped less oil). If there is nothing in the seventh position, the compressor has mineral oil in it. Electrical designations (such as PFV) are the same as other Copeland® models.
    If it ain't broke, it doesn't have enough features yet.
    Damo
    Sep 2003
    ISRAEL
    72
    4,248
    Dont forget to check if the given capcity is at 50hz, if it is at 60hz, remember to reduce 17%.
    Oct 2011
    antalya
    5
    thank you very much for answers. But i didn't find the model generation classification. I saw a write up about it. At 2001 copeland transformed KAE to KCE. 'C' took the place of 'A'. But i didn't find any information of KQE. I talked this problem with emerson employee, they said that the meaning of 'Q' was 'quite compressor'. Dou you have any idea about it? or have you got a copeland model generation classification?
    Oct 2011
    antalya
    5
    I looked up emerson website again there was too many KQE models of scroll compressors but there is no information about meaning of 'Q'. And also no information about KCE. Because of that i have to learn model generation classification. What is the reference to set in order. Has somebody get a list of this?
    Sep 2003
    ISRAEL
    72
    4,248
    take a look at this web site, it has Copeland scroll catalogues.
    In the beginning of every catalogue you will find letters explanation.
    Oct 2011
    antalya
    5
    I have already made it. But there isn't anye description about 'C' or 'Q'. They wrote only model varition. What is the* standarts of model variation? I want to learn this. For ex. how can they choose 'Q' or 'C'? what is the point of this
    Sep 2003
    ISRAEL
    72
    4,248
    Why dont you send an email to Copeland? they are very helpful.
    Oct 2011
    antalya
    5
    I have sent an email but the answer is not enough for me. I am waiting the live chat time. But i think that maybe somone know this because of that i asked the problem in here. thanks for your advice.
