Page 1 of 2 12 LastLast
Results 1 to 50 of 71
Thread: Aluminium Pipe
    don van vliet's Avatar
    don van vliet Guest
    Aluminium Pipe
    Good mrning everyone! First time poster here and was wondering if anybody has used aluminium pipe on any install jobs and was wondering how they found it?
    May 2006
    Sussex
    362
    Re: Aluminium Pipe
    Not used it and I am staying away until I hear a lot of good reports about it.... and some installation time clocked up too.
    I keep thinking about the differing coefficient of expansion of these two different metals (copper and aluminium) and I just cannot think how it can last any length of time, expanding and contracting, many times a day xWeeks xYears. Something has got to give, which is likely to be the copper stretching to match the rate of ali expansion, and then, well, fridge+ali.... sounds worrying.
    But, yet I cannot understand how a business would be selling it for aircon installs without some sound and successful testing of the product. So, I am very interested to hear about this one, in say two years, to know it is still performing properly and no rip-outs to replace with proper copper tube.
    Oct 2007
    manchester
    5,639
    45
    Re: Aluminium Pipe
    i am not using it as the recycling value is poor!!! so theres no incentive to switch to alternatives
    Mar 2011
    Singapore
    212
    Re: Aluminium Pipe
    We don't recommend to use, some distributors and suppliers are going to void their warranty in our fareast.
    Galvanic effect caused by Aluminium reacting with Copper and impact to the system is uncertain.
    The strength of Aluminium pipes are uncertain compare to Copper pipes that had been in use for decades.
    Copper has a high thermal conductivity of 400 W/mk compared to 237 W/mK for Aluminum.
    So CU is the winner but expensive than AL.
    Dec 2010
    Toronto, Canada
    1,454
    Re: Aluminium Pipe
    Due to the cost of copper, some companies (Hydro...for one) has produced aluminum tubing for solar panels and supposed to be very corrosion resistant BUT it will only last if there are absolutely no copper or brass components in the whole system. I, for one, won't be using it any time soon.
    Nov 2011
    15
    Re: Aluminium Pipe
    I have heard that aluminium pipe has been used in asia for air conditioning installations for the past 18 months with out any problems.If the costs are lower than copper and it performs the same job as copper then market forces will drive the product to the fore front of the industry.
    Jul 2011
    United States of America
    59
    86
    13
    Re: Aluminium Pipe
    Heatcraft is now making some of their refrigeration condenser coils totally from aluminum as well some air conditioning manufacturers. I have seen rooftop units in 7.5 ton with aluminum coils from Rheem/Ruud. York is manufacturing aluminum condenser coils for their residential line. The name of this technology is "microchannel". I have had a few warranty issues with pinhole leaks forming in less than one year. Can you imagine how long it would last near the coast? Not sure about how coil coating these type of units would hold up against corrosion.
    http://www.heatcraftrpd.com/products...pageNo=1&cID=2
    Jul 2011
    59
    86
    13
    Re: Aluminium Pipe
    I know my post has nothing to do with aluminum pipe, but was making the point how aluminum would not be a good idea in certain applications.
    Dec 2010
    devon
    837
    Re: Aluminium Pipe
    cant braize it it rots like hell in the uk and everything we sea a alloy coil in lasts halve the time of copper i can sea why we need it to work due to weight and cost but at the moment its not possible in our climate
    Auckland
    74
    3,357
    37
    Re: Aluminium Pipe
    Every car air con uses aluminium tubing. Vibration, heat and wet enviroment.
    Nov 2011
    15
    Re: Aluminium Pipe
    Most chiller manufacturers are now using all aluminium condenser coils. WHY ? Cost, weight. and performance. If the aluminium is not mixed with a dissimilar metal then the galvanic effect will not happen and the aluminium creates its own protective coating making it last forever!
    Dec 2010
    Toronto, Canada
    1,454
    Re: Aluminium Pipe
    Is it coated, Mr magoo? I tend to think most other components in autos are steel or aluminum so there may not be a problem.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Re: Aluminium Pipe
    That was what i was thinking Magoo. Although the only part in some vehicles, is the TX valve which is brass. Side note: I don't think vehicle a/c aluminium components are 100% pure. When making Hydrogen and using a/c parts, the chemical reaction is poor compared to using aluminium from other sources.. just an observation..Mike.
    Nov 2011
    Spain
    1
    Re: Aluminium Pipe
    We tried it on a couple of split system installations earlier in the year and have had numerous call backs for flares leaking after a month or so, maybe due to contraction/expansion which i've never had with copper?
    Had to replace with copper in the end
    Tried to save money and it cost us again!
    Nov 2011
    United Kingdom
    9
    Re: Aluminium Pipe
    I think the above comments are incorrect - the problem with current aluminium pipe is that it is of an inferior mix and you are having to use plastic inserts in the flares 'what's the point of that' - If you get a pipe with a 97% aluminium mix you will have no problems. What I would say to anyone in the industry is that it is time to change - why - because there is virtually no copper left on planet earth - what is being used is recycled and the Chinese are buying everything that is available. The industry needs to find and alternative which will make our work more profitable.
    Nov 2011
    15
    Re: Aluminium Pipe
    I totally agree Lokaro1 as I said in my earlier post its been working in Asia for 18 months with very good feed back. Its only a matter of time before we all have to change and go with aluminium.Price will be God !!
    Dec 2010
    ZA
    154
    Re: Aluminium Pipe
    Nice idea, but it will crack and will leak. Removed an old Carrier that had aluminium coils, and every joint was either cracked or brittle, most broke off just by touching them. It might work on an outdoor unit not near the coast and not used as a heat pump, but add a little salt and it will corrode in short order. As well no way to repair them, I have seen cheapie Chinese units that have a pipe kit made from aluminium, most of the time the installers throw it away and put copper pipe in. BTW, what rumour that copper is now running out? Just that now Zambia is reopening the old closed mines in the Copper Belt, and selling the output mostly to China.
    Dec 2010
    Toronto, Canada
    1,454
    Re: Aluminium Pipe
    copper IS running out, it is a semi-precious metal. A lot of boiler manufacturers are going more stainless, maybe the fridge industry will too (I am making some solar products with thin wall stainless at less than half the cost of copper)
  19. #19
    Apr 2010
    Jamaica
    34
    121
    Re: Aluminium Pipe
    Quote Originally Posted by MikeHolm View Post
    Feel free to pm me with more if you please. I am curious about how you would use stainless steel tubing.
    Visit http://www.kompulsa.com/ for technology news, reviews, and more. Twitter: Kompulsa.
  20. #20
    Nov 2011
    15
    Re: Aluminium Pipe
    Aluminium pipe will work and people will use it because the cost of copper will dictate the change.Made enquiries and there is a new product about to hit the market and by all accounts it appears to be the real deal.Will keep you all up to date if I find any more information.
  21. #21
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Aluminium Pipe
    Copper is much less corrosive, SS welds should be polished and clean with acid. You must have a nitrogen or Argon flow inside the tube while welding it or it will rust in no time.
  22. #22
    Dec 2010
    Toronto, Canada
    1,454
    Re: Aluminium Pipe
    I agree about copper Chemi, but none the less it is running out and there are options coming out. I am silver soldering stainless tubing now for some things but not refrigeration parts. I would expect it to be become more prevalent in the industry. One must pick the right grade of stainless as well.
  23. #23
    Auckland
    74
    3,357
    37
    Re: Aluminium Pipe
    A large proportion of ammonia evaps these days are coming out as aluminium fin and tubing these days, so where is the problem with using aluminium on domestic type equipment. Seems to be more of a resistance from trade people as per all the previous comments. Joining pipes is not an issue if you use quality compression fittings.
  24. #24
    Dec 2010
    Toronto, Canada
    1,454
    Re: Aluminium Pipe
    So what is causing all the reported leaks, compression fittings excepted?
  25. #25
    Auckland
    74
    3,357
    37
    Re: Aluminium Pipe
    Hi Mike.
    I can only imagine the quality of alum., is the real issue. In industrial applications the coils are defrosted with hot water, sanitzed with chemicals the whole 9 yards, as well operate with sauced products which add more corrossive stuff. Not a problem. Coils rated for ammonia at design ratings +50 'C.
  26. #26
    Nov 2011
    United Kingdom
    9
    Re: Aluminium Pipe
    Why now and Why Aluminium?
    It is a known fact that the Global copper market is now in deficit, it’s cost is rising and in the years to come, many of us will encounter problems
    With SUPPLY of copper due to increased consumption of copper by China.
    The price of copper rose 27% in 2010 on 2009 levels indicating that copper tube could be seen as becoming too expensive for installers
    To purchase and acts as a trigger for growth of an alternative metal.
    Following our research we are now bringing to the market some “know-how” with a product which fits our current and future economic climate
    An Aluminium Tube for the Air conditioning & refrigeration industry, with high technical performance and reliability comparable with the rates
    Of production of copper.
    In addition aluminium tube has several advantages which are presented below;
    Why aluminium tubes better?
    Escalating Copper Prices
    Shortage of 199,000 ton in 2011 (Standard Bank Plc)
    Shortage of 457,000 ton in 2012 (Standard Bank Plc)
    Average price at USD 8700/Metric ton in 2012
    Supply shortage due to deterioration of copper ore and lack of further investment
    Price Trend – Sideways or Up
    Why Copper was chosen as the pipeline for air conditioning & refrigeration?
    Due to the hardness and rigidity
    Can be easily repaired
    Prices in year 2000 for copper +/-1300/metric ton comparing to 2300/metric ton
    Why Aluminium Now?
    Stable and low prices compared to copper (approximately 1/3)
    Abundant Inventories
    Higher thickness to compensate in rigidity & hardness yet maintaining lower prices than copper
    Can be easily joined or repaired with our special formulation brazing rods
    Aluminium Source & Inventory
    Aluminium is the most abundant metal in the Earth’s crust, and the third most abundant element,
    After oxygen and silicon. It makes up about 8% by weight of the Earth’s solid surface
    Size Length
    1/4 50m
    3/8 50m
    1/2 50m
    5/8 50m
    3/4 50m
    Characteristics & Advantages over copper
    Flaring
    Requires lesser strength
    Uses the same set of tools as flaring copper
    Higher thickness on pipe enables a more strong and even flare
    Bending
    More flexible than copper
    Does not kink easily compared to copper
    Uses the same set of bending tools as copper
    Brazing
    Special formulation rods allow up to 50 joints
    Fast, easy and secure joints in 10 seconds
    No turning of torches or rounding up gaps
    4 times faster than brazing copper
    No additional flux required
    Uses same torch or turbo torch
    More saving on gas, time and brazing rod due to lower melting point of aluminium
    Joints are stronger than main material
    Estimated GBP 3p per joint
    Swaging or Expanding
    30% expansion from original OD
    Uses the same set of swaging tools as copper
    Longer length Coils – Coils come in 50m (larger sizes) & 100m lengths minimising joints
    Lesser joints would mean lesser tendency of leakage
    Uses less time, gas and brazing rods
    Pressure
    Pressure tested to meet CE regulations
    Certificates available
    Corrosion
    48 salt water test before shipment
    Corrosion rate is very much less than copper
    Oxidisation rate is also lower making pipes clean and bright when exposed
    Thermal Conductivity
    Lower than copper by almost 50% which means lesser rate than copper
  27. #27
    Nov 2011
    United Kingdom
    9
    Re: Aluminium Pipe
    For more information just go where I have been looking http://www.aluminiumrefrigerantpipe.com/
  28. #28
    Jul 2007
    Australia
    1,845
    Re: Aluminium Pipe
    Got a vested interest in selling aluminium piping?
    BTW, never seen the yanks spell it as aluminium before,as this spell checker keeps telling me it's aluminum.
    All seems a bit suss to me, new 1 post member asking the question, then lokaro1 bounding in, giving us some USA styled site but spells it the proper way. I think this is marketing/spam.
    edit: cut and paste the link above, whats that all about? Never seen one so long, looks like tracking clicks from this site for sure.
  29. #29
    don van vliet Guest
    Re: Aluminium Pipe
    Not at all, used the aluminium as a trial last week and it was shocking to use, one joint in particular just wouldn't take for some reason? Btw Paul, you shouldn't make assumptions without evidence, learn to keep your opinions to yourself ok?
  30. #30
    Jul 2007
    Australia
    1,845
    Re: Aluminium Pipe
    double post 10char
  31. #31
    Jul 2007
    Australia
    1,845
    Re: Aluminium Pipe
    Ok, so you used aluminium piping last week, found it bad, but said nothing until a week later, one hour after I called the situation a bit suss?
    Yeah right.next you'll say it was only bad aluminium because you didn't get it from aluminiumrefrigerantpipe Why didn't you say anything before? Why take such offense when my point was another poster going on about aluminium piping, not you? It's like you were monitoring the thread under a different alais to me. Being so quick to respond, but never giving any feedback before hand...
  32. #32
    don van vliet Guest
    Re: Aluminium Pipe
    Calm down dear
  33. #33
    Oct 2001
    Nottingham UK
    5,668
    Re: Aluminium Pipe
    Looks like our friends Boxer, Dan Van Vleit, and Lokaro1 are the same person - according to their IP address
  34. #34
    Nov 2011
    3
    Re: Aluminium Pipe
    N00bs, what fools to underestimate IP powers.
  35. #35
    worst_adm1n_eva's Avatar
    worst_adm1n_eva Guest
    Re: Aluminium Pipe
    Delete the thread and them then. Don't give the the benefit of the discussion and the dodgey link
  36. #36
    Jul 2007
    Australia
    1,845
    Re: Aluminium Pipe
    Glad to see you're on the case Frank.
    I may be a cynical old *******, but really I can only rely on good mods that have access to IP and other stuff to validate it.
    I can smell crap from a mile away, sometimes too late though, so it sticks for a while.
    I'm glad to be shot of any recent crap I may have picked up recently.
  37. #37
    Aug 2010
    77
    Re: Aluminium Pipe
    Quote Originally Posted by install monkey View Post
    What if you fill the Ally pipe with sand and bang the ends over before weighing it in?
    You cant go back to that Tat man again though?
  38. #38
    Aug 2010
    77
    Re: Aluminium Pipe
    Quote Originally Posted by don van vliet View Post
    I was wondering if anyone can suggest a good Air Conditioning Unit, close control, built in the Uk but the Company owned by a massive, German Engineering Company. I'd like the cabinets to be a dark blue/grey colour and I'd like the units name to rhyme with Benco?
    Any ideas?
  39. #39
    Aug 2010
    77
    Re: Aluminium Pipe
    Quote Originally Posted by Gideon Beddows View Post
    Any ideas?
    Funny you should ask that, Gideon but i would suggest 'Denco'
  40. #40
    Nov 2011
    United Kingdom
    9
    Re: Aluminium Pipe
    I really don't like the feedback here - 27 years in the industry and offering my advice as to where I see the marketplace going. Only time will tell but for sure it will happen
  41. #41
    Mar 2007
    manchester
    63
    Re: Aluminium Pipe
    copper rules
  42. #42
    Jun 2009
    Lusk , Dublin
    1,115
    Re: Aluminium Pipe
    MMMMMMMMM...
    One suspects someone is gainfully employed by an A/C manufacturer with a name that rhymes with Benco
    Stu
    Tool's ? check ! Condom's ? check !
  43. #43
    Oct 2007
    manchester
    5,639
    45
    Re: Aluminium Pipe
    TONTO- haha
  44. #44
    Oct 2001
    Nottingham UK
    5,668
    Re: Aluminium Pipe
    The IP address does relate to the Company though so they may be different people from the same office.....pity I don't have a crystal ball.....ouch
  45. #45
    11,025
    Re: Aluminium Pipe
    Quote Originally Posted by lokaro1 View Post
    Sadly the feedback you and yours received was self inflicted.
  46. #46
    Dec 2010
    Toronto, Canada
    1,454
    Re: Aluminium Pipe
    So, Lokaro1, are you Don? Might as well ask directly
  47. #47
    Nov 2011
    United Kingdom
    9
    Re: Aluminium Pipe
    No I am not Don - nor am I Boxer - just a director of a company with 27 years experience - and the moderator Frank can't even be bothered to reply. I think I will address the site with the Institute of Refrigeration
  48. #48
    Dec 2010
    Toronto, Canada
    1,454
    Re: Aluminium Pipe
    Frank might be out working like the rest of us (or sipping Harvest Pale, as he is wont to do) and it is up to him if he replies.
    To some on here, it looked a bit suspect and that is all.
  49. #49
    Nov 2011
    15
    Re: Aluminium Pipe
    Hey Paul_h and Frank are you the same person ?
    And the crap you can smell is your own dinosaur dung
  50. #50
    May 2006
    Sussex
    362
    Re: Aluminium Pipe
    Looks like our friends Boxer, Dan Van Vleit, and Lokaro1 ...have the same IP address
    I think the point being make, Boxer/Dan Van Vleit/Lokaro1, is that you should at least highlight your vested interest and the common I/P address, too, when posting on these boards, particularly on this subject which is practically an advert for ali. It did look like (still does) like one of you pitched the OP just so that the other two could come in later with all the positive spin that would possibly sway us all over to this wonder metal, aluminium.
    We don't like being manipulated like that. Had far too much of this from Blair/Brown/Cameron/Murdoch, so are quick to spot it. Shame to spin an important thread like this one in that way. At least we know more about your position on this matter, now.
