    Dellboy's Avatar
    Dellboy Guest
    Beko thermostat wiring
    Hi all,
    I have a beko cda752fw. I cant remember which way round the brown and black wires go.It has 3 wires 2purple to one of the terminals and a black wire to a terminal and a brown wire to a terminal.The 2 latter spades on the thermostat are perpendicular to each other.They are numbered..Could anyone tell me which terminals the wire brown or black goes to .If you know it would be much appreciated.Thanks
    fridgemaker23's Avatar
    fridgemaker23 Guest
    Re: Beko thermostat wiring
    There should be a wiring diagram in the manual. If you can't find the wiring diagram, I would look online for one. Without looking at it, this would be a tough decision to make. Plus, I wouldn't want to cause damage!
    Apr 2006
    55
    1,908
    30
    Quote Originally Posted by Dellboy View Post
    Hi all,
    Hi Dellboy
    the brown/black will be your live and thermostat switched live
    it does not matter which way they go unless there is a diode in the thermostat (cant see why)
    check for voltage on the other two terminals
    connect either the black or brown
    check voltage on the other
    R's chillerman
    If the World did not Suck, We would all fall off !
    fridgemaker23 Guest
    Have you had any luck solving this? These types of things can be confusing. As I said above, the wiring diagram will be the best help. Have you considered consulting a San Francisco electrician?
