    Dec 2010
    Mozambique
    56
    11
    natural gas as refrigerant
    Hi All
    Can someone explain if natural gas can be use as refrigerant?
    Rgs
    Apr 2006
    55
    1,908
    30
    Re: natural gas as refrigerant
    Hi Springmaster
    Its a dirty gas (contaminants/water)
    R's chillerman
    Dec 2010
    Mozambique
    56
    11
    Dirty gas means hamful to ambient? or contains contaminates that are not easy to take out?
    Apr 2006
    55
    1,908
    30
    Hi springmaster
    contaminants that will contaminate the oil/system
    you would need a purification plant to remove them
    http://en.wikipedia.org/wiki/Natural-gas_processing
    R's chillerman
    Oct 2006
    1,843
    Quote Originally Posted by springmaster View Post
    Hi All
    Rgs
    In short yes.....
    But I would not like to use it because as the Chill mister says it is dirty and wet.
    It also contains other gasses that are not what you want in the system.
    Refrigerant grade gas is refrigerant grade because it is dry and almost pure quality.
    If you use natural gas your system will suffer moisture problems and contamination...
    By the time you clean, filter, dry and process the stuff you could have bought the
    refrigerant grade for a fraction of the cost and it would work straight from the cylinder.
    All the best
    taz
    Mar 2006
    Merate (LC) - Italy
    52
    2,549
    If by natural gas you mean ch4 (methane) as all other alkanes (propane, butane, etc...) yes, it can be used as a refrigerant for ultra-cryo temperatures (boiling point -161°C). As said by other, it needs to be purified to refrigerant grade.
    Dec 2010
    Mozambique
    56
    11
    Thanks for the explanations
