Results 1 to 30 of 30
    Apr 2010
    Jamaica
    121
    Reverse Cycle Air Conditioning
    Hello.
    A quick question. Do reverse cycle air conditioners actually reverse the compressor or is it just a valve that they use to divert the refrigerant?
    Apr 2006
    55
    1,908
    30
    Re: Reverse Cycle Air Conditioning
    Hi Kompulsa
    I will jump on this one mate, as most engineers would not know this !
    The compressor I think
    R's chillerman
    Oct 2008
    newbury
    1,444
    Quote Originally Posted by chillerman2006 View Post
    Hi Kompulsa
    R's chillerman
    Sounds reasonable. I have just fitted a flexiflow water pump which shows when you connect the pump(bl-bl & r-r) it runs clockwise but if you reverse the wires (bl-r & r-bl) it will run anti-clockwise
    cleaver stuff these wiggly amps
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Quote Originally Posted by Kompulsa View Post
    Hello.
    My answer is: the valve changes the direction of refrigerant flow . One way street here, no reversing the compressor. BTW, love the Jamaican Rum!!
    Apr 2006
    55
    1,908
    30
    Quote Originally Posted by mikeref View Post
    Hi Mike
    are you sure about that mate or is it the ''Rum'' talking
    may be you could explain for the 'original poster' 'RB' & myself how this all works
    if you could start with the vapour compression cycle in cooling mode
    & then break us in slowly to reverse cycle, would be most useful
    R's chillerman
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Hi Mike
    R's chillerman
    Oh... Would be happy to do so, but i seem to remember a previous engagement with my bottle of spirits and the "sandman" tonight. Maybe some other time then?
    Dec 2010
    Toronto, Canada
    1,454
    One direction CM, reversing valve changes the flow direction.....Appletons is my fav rum....yum
    TRASH101's Avatar
    TRASH101 is offline Veteran Poster I am starting to push the Mods: of RE
    Mar 2007
    394
    If the flow of time reversed then that would be a "real" reverse cycle!!!!
    Although a valve might also do the trick
    Quidvis Recte Factum Quamvis Humile Praeclarum.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    So it seems we have some "For" and "against" here. Think i'll go with Trash101 at this time. Seems reasonable in my current state of mind thankyou..
    Apr 2006
    55
    1,908
    30
    Yeah, enjoy your zzz's mate
    Quote Originally Posted by MikeHolm View Post
    Mike, check out the picture, will save the rest of this, just in case you get round to visiting us in the uk !
    Quote Originally Posted by TRASH101 View Post
    Hi Trash
    if ever you discover that one mate, keep me in mind for a beta copy
    R's chillerman
    Apr 2006
    55
    1,908
    30
    Hello.
    Hi Kompulsa
    See attached picture
    R's chillerman
    Oct 2008
    newbury
    1,444
    I can assure you my water pump specifically states you swap the wires to change the direction. This is very confusing....
    Oct 2006
    1,843
    There is no refrigeration compressor that I know of that runs in reverse.
    Think about it?
    A recipricating piston compressor does not know which way it runs because the rotation is
    converted into up and down motion. It is the valves that direct the gas.
    A scroll can only run one way
    A screw can only run one way
    A centriff also.
    I'm not sure of a rotor????
    So the compressor always runs and always sucks through the suction
    and out through the discharge.
    It is the valve that moves to create the flow to move in the oposit direction.
    All the best
    taz
    Apr 2010
    Jamaica
    121
    Thank you. I believe that the compressor doesn't reverse either. My Toshiba datasheet says that it is for the Heating and Cooling type of air conditioner and nearer to the bottom it says "do not try to reverse compressor".
    Apr 2006
    55
    1,908
    30
    Hi RB
    I remember a screw compressor wired red, blue, yellow (by another I hasten to add)
    That ran backwards too, but for some strange reason needed replacing
    I decided to go for red, yellow, blue and thats was ok
    R's chillerman
    Dec 2010
    Toronto, Canada
    1,454
    Current state meaning RUM?
    Oct 2006
    1,843
    Water pump?
    It will most likely use a small vane so rotation could be in both directions.
    But think of how most water pumps work?
    They draw water in from one side and the rotor, turbo, centrif, vane or waterever
    they are called, then spits the water out through the other hole. So even a normal
    water pump would struggle with direction.
    If it is a peristaltic type pump they run either direction.
    All the best
    taz
    Dec 2010
    Toronto, Canada
    1,454
    Hi Kompulsa
    See attached picture, looks I may be wrong !
    R's chillerman
    I should have made a wager on in for the bottle of rum.....
    Dec 2010
    Toronto, Canada
    1,454
    "Circulator" type or any other type of pump that takes liquid from the suction at the centre and discharges from a spot on the edge of the impeller will not work well backwards (Grundfos, Wilo, any inline pump). The impeller and the input output geometry must be symmetrical (or nearly so) and scrolls for sure are not symmetrical.
    Positive displacement such as vane or lobe pumps can do it.
    Oct 2006
    1,843
    Hi RB
    R's chillerman
    I remember a Bitzer semi hermetic srew that had a faulty discharge
    one way valve and when it turned off the gas just reversed the
    the screws and it ran backwards.
    The only problem was the main bearing is also a thrust bearing and
    they are designed for the load in one direction only. When the thing
    ran in reverse it put loads on the bearing in the wrong direction and
    it siezed up.....
    All the best
    taz
    Apr 2006
    55
    1,908
    30
    Quote Originally Posted by taz24 View Post
    it siezed up.....
    All the best
    taz
    Hi Taz
    yeah easy to spot mate, in reverse by the sound they make
    the one I refer to (also a bitzer) had only run a short period of time
    but by time I got there & rewired it was too late
    the compressor went down the following day
    R's chillerman
    Oct 2008
    newbury
    1,444
    Water pump?
    All the best
    taz
    They are not called heat PUMPS for nothing I can tell you..
  23. #23
    Oct 2008
    newbury
    1,444
    I stand corrected..
  24. #24
    Oct 2006
    1,843
    Cheeky.
    I'll tell on you young mister Bartlett if you don't stop picking on me
    All ther best
    taz
  25. #25
    Apr 2010
    Jamaica
    121
    I'm pretty sure that mine is at least the type that does not reverse but can be used with reverse cycle systems. i wonder if mine is specifically made to handle cycle reversal or if they just use standard compressors.
    Visit http://www.kompulsa.com/ for technology news, reviews, and more. Twitter: Kompulsa.
  26. #26
    Apr 2010
    295
    wot about the little guy inside the unit that turns everything around so it works backwards
    I can fix broke but I cant fix stupid :)
  27. #27
    manchester
    5,639
    si is that the same lil guy in the atm machines and the photo booth's haha
  28. #28
    Apr 2010
    295
    yeah theres loads of them bet they get paid well
  29. #29
    Jun 2009
    Lusk , Dublin
    1,115
    You can hire them wee lads ,
    Try Access All Areas ,or Rent a runt ,
    Very handy for those tight shafts or passing the time on your breaks by seeing who can throw him the furthest .
    Stu
  30. #30
    Jul 2011
    United States of America
    59
    86
    13
    Just another name for "heat pump".
    http://www.youtube.com/watch?v=TqlYsXnICXw
