Results 1 to 10 of 10
    Somerset
    69
    4,697
    Reducing a condensate line from 32mm plastic?
    Hi Guys!
    Have a slight dilemma here, basically I am finishing off a new install of Fujitsu Ceiling cassettes.
    These have a condensate outlet sized at 32mm Plastic.
    Because they are not direct replacements the existing drain line holes no longer line up and for various reasons cannot be reused.
    So my question which may seem rather basic to some is.
    What is available to allow me to reduce these lines down, the only holes I have available ( in wall!) are around 3/4".
    Has anyone come across this dilemma and how have you resolved it?
    Thanks Grizzly
    PS. If poss, are parts available from national and therefore local suppliers?
    Jul 2009
    stoke on trent
    48
    Re: Reducing a condensate line from 32mm plastic?
    dean & wood have a good selection of reducers etc 32mm- 3/4 abs or plumb centre, hope this helps
    Somerset
    69
    4,697
    Thanks Reg.
    That's a good tip.
    Sadly my nearest is 40 mls away!
    Oct 2007
    manchester
    5,639
    45
    grizz - check the name on the original drain pipe
    if centre brand- go plumb ctr
    lasco - travis perkins
    george fischer- plastics ctr/drainage(wolseley)
    or diversey do rubber boots to reduce from 11/2 11/4 to 3/4 in different colours then jubilee clip em to be on the safe side
    3,856
    Climate and rpw do some rubber adaptors that go from 1 1/4" down to overlow pipe size, think they are made by Sauermann, needs jubly clips or will leak.
    Good thing with these is you can undo them if needs be. Beware different makes of overflow often don't fit well together despite being the same nominal size.
    Jon
    ireland
    1,450
    41
    if all else fails pour wavin glue on end of pipe, flick lighter and warm gently for a few seconds, you now have an instant adaptor for close matching pipes, a plumber by the name of larry the leak told me this one
    al
    Somerset
    69
    4,697
    Thank you my friends and god bless Larry the leak.
    Were I am working they have a "Plumber" called Leaky Lee!
    I am sure I will source something from the leads I have.
    11,025
    Maybe not the ideal solution but there is always good ole heat shrink tubing for those hard to get thingys'''
    http://www.flints.co.uk/acatalog/Hea...nk_Tubing.html
    Only shrink the ends over the spigots though.
    Oct 2008
    newbury
    1,444
    37
    Somerset
    69
    4,697
    A very useful link.
    Were necessary I use self amalgamating tape. Its ideal when dealing with water sealing issue and no heat application required.
    Available just about everywhere.
    http://www.wppltd.demon.co.uk/WPP/Co...tml#selfamaltp
    Thanks Brian.
