Results 1 to 23 of 23
Thread: LL Sight Glass Mounting
Threaded View
11-10-2011, 07:44 PM #11
Re: LL Sight Glass Mounting
Hi jwasir
mount it anyway that looks the prettiest to you mate, the point I/we are making is dont use the sightglass as an indication of correct charge, just for moisture indication
check your charge by running at fall load and check temps/pressure
95% of all sight glasses I see are mounted horizontaly and the other 5% vertically with flow going up, all done by manufacturers
R's chillermanIf the World did not Suck, We would all fall off !
