Results 1 to 10 of 10
    Apr 2010
    Jamaica
    121
    Capacitor Size Required for 9,000 BTU
    Hello.
    Does anyone know what capacitor size is required for a 9,000 BTU standard single phase compressor?
    Apr 2006
    55
    1,908
    30
    Re: Capacitor Size Required for 9,000 BTU
    Hi Kompulsa
    all cap sizing differs, no good wild guessing
    you will either need the original to match it with
    the schematic for the compressor or the unit
    or will need to ask supplier that stocks that compressor
    or the manufacturer
    R's chillerman
    Jul 2007
    Australia
    1,845
    Start cap, run cap, PSC cap?
    Apr 2010
    Jamaica
    121
    Quote Originally Posted by paul_h View Post
    Run capacitor.
    3,853
    Based on the supplied information i'd say, and i caution you its only a guess, one about 35mm round by 80mm long would do....
    Always fit the same type and capacitance as fitted by the manufacturer, you can go higher on voltage but not lower. If all else fails, look at another unit by the same manufacturer and see whats on that one.
    Apr 2006
    55
    1,908
    30
    Haha, nice one mate
    R's chillerman
    3,853
    Quote Originally Posted by chillerman2006 View Post
    Haha, nice one mate
    R's chillerman
    I know people who used to size them by the dimensions! They had an oxygen reg for thier nitrogen bottle to so could only test to 14psi.....
    Apr 2006
    55
    1,908
    30
    OMG, this industry has some real genius's and some from the other end of the scale, lmao
    R's chillerman
    Dec 2010
    ZA
    154
    I had caps that were faulty ( would not pass acceptance test as ESR was off scale) so sent back to stores. Got them back again, they did a VISUAL check, and found them within specs. Sent back again with leads cut off...
    Sep 2003
    ISRAEL
    72
    4,248
    25mf 400volt capacitor will do the job.
