Results 1 to 2 of 2
    May 2011
    EGYPT
    11
    Alfa laval evaporator
    I have alfa laval but i hope to find the cooling capacity .
    Alfa laval ibl 12 577 sv
    alfa laval irl 555 sa
    alfa laval isc 16 16 pa
    alfa laval irl 14 668 p -e
    i hope to help me to find data about it
    Referencer's Avatar
    Referencer Guest
    Re: Alfa laval evaporator
    The IBL and IRL evaporators are part of the industrial range, Airmax II family. The ISC is a centrifugal unit cooler.
    To find the capacity of these, you will have to provide the air on temperature and the evaporating temperature, as well as the refrigerant used.
    With that data, maybe someone could rate them, using either a selection program or printed documentation ...
