Results 1 to 14 of 14
    3,362
    Frick screw bearing damage
    Hoping someone can assist, with analyizing main roller bearing damage in a Frick screw
    on ammonia.
    I have previously seen an article on Frick oil filters also showing damaged bearings &
    cause of bearing damage.
    Thanks Ranger
    Aug 2007
    Adelaide Australia
    70
    562
    Re: Frick screw bearing damage
    Hi Ranger
    What is the damage to the bearings.
    Have you asked a bearing supplier for their opinion sometimes they will help.
    Paul
    3,362
    Paul,
    Damage to drive end bearing male rotor is a little unusual.
    It has a spiralling heavy wear pattern.
    I could ask bearing supplier, but sometimes difficult if you did'nt buy bearings
    off them, as we are using genuine frick bearings.
    Thanks for advise
    ChillerMechanic's Avatar
    ChillerMechanic Guest
    http://www.irc.wisc.edu/file.php?id=214 here's a good article on bearing failures
    3,362
    Quote Originally Posted by ChillerMechanic View Post
    Thanks ChillerMechanic, its a good article.
    Jun 2009
    Canada
    55
    82
    15
    Hi Ranger1
    Have you a photo or two we call look at?
    Dec 2006
    Iran
    43
    55
    Hi ,
    Do you check the coupling of compressor and drive? it should be adjusted according to the manual . may be the angle of spacer of coupling is not correct.
    Dec 2011
    Canada
    11
    Paul,
    Damage to drive end bearing male rotor is a little unusual.It has a spiralling heavy wear pattern.
    Thanks for advise
    In our cases, we mostly see damage to the male thrust bearings first. Also, I highly doubt that a bearing supply house provides genuine Frick bearings, which to my knowledge are SKF. In my experience, you need to be careful of avoid using jobber bearings as Frick may have specified a certain internal clearance (C3, C4's) or other specifics which you simply cannot decipher by reading the bearing number off the race.
    Dec 2008
    chapeco
    hello. please what is the axial compressor frick HSDD 233l, some change in this play if it works in -10 ° C and -35 ° c is working, grateful
    Dec 2008
    chapeco
    hello. please what is the axial compressor FRICK TDSH 233L
    Jul 2007
    Czech
    61
    374
    Diego is not a problem, Frick does not separate low and high.
    Dec 2008
    chapeco
    What is the tolerance of slack in the thrust bearings 233 FRICK??
    3,362
    Quote Originally Posted by diego palma View Post
    At a guess
    0.001" to 0.0054"
    DEC 0.0075" TO 0.0095"
    Dec 2011
    Canada
    11
    0.0015" if memory serves me right.
