    May 2008
    malaysia
    40
    82
    expansion valve for evaporator
    hello everyone
    how can i select the correct expansion valve for the water cooling tank evaporator
    system 1
    lenght for each steel pipe 6m
    thickness 3mm
    OD 1 1/4''
    total pipe in parallel 30
    system 2
    lenght for each stainless steel 316L pipe 6m
    thickness 1.5mm
    OD 1''
    total pipe in parallel 20
    thanks in advance....
    Dec 2008
    Portugal
    48
    1,020
    Re: expansion valve for evaporator
    First you need to know the refrigerant capacity and the operating conditions. The capacity depends on the temperatures of the fluids, mass flows,...give me thermodynamic data.
    May 2008
    malaysia
    40
    82
    actually i am electrical engineer but new to refrigeration industry, what is mean by thermodynamic data. Could u pls explain?
    i need to cool down the acid in aluminium industry,
    acid tank 4ft wide, 25ft lenght, 9ft deep
    acid temperature 30dec
    i need to cool down to 20dec
    if for the 6m, 1 inch, 1.5 thickness stainless steel 316L pipe
    1.how long that i need for the evaporator design
    2.the expansion valve and the total cooling capacity?
    thanks for reply.
    Dec 2008
    Portugal
    48
    1,020
    First at all I need the sensible specific heat (cp) kJ/kg.K on SI units is needed or in another units, then I make the conversion. Also I need to know the time you need yo cool from 30 to 20ºC.
    Aug 2009
    New Zealand
    2,554
    I would suggest that you employ a refrigeration engineer, to design and build the system.
    Nov 2003
    holland europe
    66
    78
    get yourself coolpack from denmark.
    computer shooter
    paul deelen
    +31653300739
