    Oct 2011
    Bromsgrove, Worcs
    32
    Carrier Starter Guard
    Hello, does anyone know what the 3 LEDs on a Carrier stater guard refer to. There is a green one at the top and red fault indicator in the middle and an amber one at the bottom
    Jun 2009
    North East England
    35
    714
    14
    Re: Carrier Starter Guard
    The green is board healthy
    Amber is comms
    Red is board fault
    The red should only come on it the cch or board fails also it the chiller starts the compressor and the
    In built toroid does not detect curent from the compressor ie earth or overload fault
    IRS Ltd's Avatar
    IRS Ltd Guest
    Many Thanks,
    Had a problem where the green light was fluctuating between bright and dim before start up but after I changed the board it was OK
