Thread: daewoo frsu20dcb problem
05-10-2011, 06:57 PM #1
I have problem with a daewoo frsu20dcb that has an alarm that chimes when the door is left open but it's going off every now and then with the doors shut. Can't find any problem with the door switch on either door so wondered if anyone had come across this before.
thanks.
tony
05-10-2011, 07:14 PM #2
Re: daewoo frsu20dcb problem
is it holding the correct temp as had them where alarm goes off due to air sensors failing..
06-10-2011, 12:25 AM #3
Air sensor also watch for evap fan not running. Fan motor appears fine but occasionally shuts off as pcb not happy with motor function.
