Results 1 to 2 of 2
    May 2011
    EGYPT
    11
    Stal vertical screw model rva 55
    data with stal
    is :
    model : rva55-BAE BBB - AGB -CAB - A
    288 M3/H
    4200 UPM
    MOTOR 55 KW
    >>>>>>>>>>>>>>>>> BUT I NOT HAVE THE COOLING CAPACITY
    SO I HOPE TO HELP ME
    i have Stal vertical screw compressor rva55 and i can not find any data about it if any one have the stal equivalent model to it , plc sent to me
    tamer_alwaha@yahoo.com
    Jan 2006
    Croatia
    68
    2,261
    31
    Re: Stal vertical screw model rva 55
    Hi, tamer zanaty
    Quote Originally Posted by tamer zanaty View Post
    I WANT TO HELP ME TO FIND COOLING CAPACITY OF STAL VERTICAL SCREW COMPRESSOR
    data with stal
    is :
    288 M3/H
    4200 UPM
    MOTOR 55 KW
    You have your compressor capacity - 288 m/h, just follow this link, please ... hope will be of some help to you...
    http://www.refrigeration-engineer.co...essor-Capacity
    Btw, your refrigerant, seems, is ammonia (rva) or ... with different refrigerants and different evaporating temperature capacity is different...
    I'm sure you can find a lot of info/answers just surfing RE forums...
    Best regards, Josip
