Results 1 to 9 of 9
    Sep 2011
    37
    5
    adding additional gas on mitsubishi r2 system
    I need to add 7kg of additional gas to a r2 system what is the best way to put it in ??? Should i open valves and run up first or put it straight into pipework ???
    Jun 2009
    Lusk , Dublin
    1,120
    Re: adding additional gas on mitsubishi r2 system
    Vac it down and lob it into the pipe work.
    Open valves slowly when charged .
    Any other additional gas can be flashed into the suction line.
    Stu
    Tool's ? check ! Condom's ? check !
    Sep 2011
    37
    5
    cheers mate , im best running it in cooling arent i and throttling the liquid in slowly then to get rest of it in ??
    Oct 2007
    manchester
    44
    5,707
    normally you will get it all in=if the charge is calculated correctly but if not stick it in test cooling and throttle it into ur suction line
    Sep 2011
    37
    5
    i am asuming the charge is correct because its been reclamied by someone and now ive been asked to a recharge the system now we have moved a fan coil , ive already put 10 kg back in but ran out of time to get final 6kg , was a bit unsure if running it short of 6kg would damage it
    Oct 2007
    manchester
    44
    5,707
    if i reclaim gas i use the reclaim rig to pump it back in,no loss then
    Sep 2011
    37
    5
    Sep 2011
    37
    5
    yeah thats what i used mate to get that much in so far .... would you advise carrying that on til all in , then open valves ??? ...or open them up and test cool and throttle rest liquid in ???
    Oct 2007
    manchester
    44
    5,707
    u can open the valves and reclaim it all back into the system prior to running
