Thread: Lg gr572tvf problem
29-09-2011, 03:54 PM #1
Lg gr572tvf problem
Hi im currently having a problem with my fridge.
The freezer part is working fine but the fridge part is not getting cold at all
Help please
29-09-2011, 06:19 PM #2
Re: Lg gr572tvf problem
make sure none of vents are blocked and that the damper is working also check control temp sensor
29-09-2011, 07:45 PM #3
Hi Just try to switch off the refrigerator so it will get rid from all the ice because probably you have a blocked vent with ice and switch it on again, i think you will need to leave it off for about ten hours, If this problem occurs again after a week or two then you have a defrost problem it might be a faulty defrost timer,defrost heater or a sensor
