Page 1 of 3 123 LastLast
Results 1 to 50 of 120
    Sep 2011
    NZ
    Can you help us please?
    Hello
    New to this site recently. Our air conditioning had a small leak, so we vented the remainder to space and pulled system pressure to space too, recharged to 7k superheat and 10k subcooling and it now works fine accept when we have sun. We believe its either an issue with unprotected radiant heat or an overload of neutrinos. Can anyone advise? High side is 21bar temperature 90k = superheat 20k. Low side is 12bar temperature 6k = superheat 7k. Liquid line is 24k = subcooling 10k. Pressures and temperatures remain quite stable even when on sun side but it just fails to cool, what could be the problem, the only problem we see is an intermittent drop in suction pressure and rise in temperature which subsides as soon as sun is down. Our oxygen regenerator seems to be working below design also when suction pressure drops. Thankyou
    3,856
    Re: Can you help us please?
    Hi Aussie!
    I think the trouble here is since last week when neutrinos became able to exceed the speed of light that, anything you try and cool will in fact warm up before you've even started, try fitting a relay in the feed to the reversing valve so that it defaults to heating, that way it will cool before its even started and you'll save some energy you can then use to boost the perfromance of the oxygen generator.
    I have had some success in the past with revesing the polarity but is not an ellegant soltion and best left as a kill or cure measure imho.
    MS
    Sep 2011
    NZ
    Hello
    could anyone help, who does actually understand refrigeration and physics a bit more than the monkey?
    It is running R410a and I have made a typo error discharge temperature is 54k. Can an experienced refrigeration engineer confirm these pressures look good and help put the monkey back in her cage. Thankyou
    Somerset
    69
    4,697
    Aussie.
    You insult a very esteemed member.
    Talk in Kelvin when not necessary then expect the rest of us who are here to help, to take pity on you.
    Your first post was full as far as I could understand it, of bad practice and poor information.
    It's a wonder Monkey even bothered to answer!
    As we say around my part of the world.
    "On Your Bike!"
    You may know physics but you don't appear to know how to ask!
    Sep 2011
    NZ
    Hey come on, first the monkey & now the grizzly bear with a sore head, what is this a Zoo? Can anyone help me please that is not a caged animal ? Thankyou
    Apr 2010
    295
    15
    Aussie.
    "On Your Bike!"
    well said that man tell him to sling his hook
    I can fix broke but I cant fix stupid :)
    Sep 2011
    NZ
    Now Its a monkey shivering, is that from the weather or the chill pills? Is there any zoo keepers on here tonight, to round up the animals, can anyone help me please?
    Apr 2010
    295
    15
    if yr in the vaccume of space just pop over to the hatch open door and get me an outside temp reading with a calibrated hand held thermometer will only take u a mo will be happy to help then
    3,856
    On second thoughts i'd be investigating oil waxing issues if you temperatures are correct and given you location in outer space, though i'd expect the effect of the sun would be helping and not hindering operation, curious!
    If all else fails, open a window
    Sep 2011
    NZ
    Thankyou
    Currently outside temperature is fluctuating between -185k and -247k it appears to be an abnormality of a solar storm we are currently experiencing, btw earths sheild seems to be flexing quite a bit from up here, are you having strange pressure readings on land?
    Sep 2011
    NZ
    Hello Simon
    are you ok working at these temperatures, you are the only one here who understands, I have pulled a excellent vaccuum prior to charging and it only took 12 seconds, remarkable
    Sep 2011
    NZ
    Hello again monkey
    we have illiminated oil from our systems and have replaced traditional compressors, with a modified jet compressor that work very well, maybe I under estimated animals, you do appear to understand flux points for waxing. Have you experienced jet compressors with what we call widget moderation control?
    3,856
    Quote Originally Posted by AussieIce View Post
    Hello again monkey
    AHA!
    Some of those jet compressors use magnetic bearings, be sure your bearing magnetometer ecu is correcting for the influence of the earths magnetic poles, you may need to interface a Helmholtz calibration system to eliminate diurnal variations in the earths fields.
    I've found Billingsley Aerospace & Defence a good source of these, though not cheap.
    ireland
    1,450
    41
    OP
    Watching this may help? Maybe light something up, a good Hamlet maybe, sit back and enjoy.
    al
    Jun 2009
    Lusk , Dublin
    1,115
    Hey AussieIce
    You didn't happen to see an old satellite hurtling past your window while you were playing with your widget did you ?
    If so any idea where it was heading as a few of us are running a book on where it's going land .
    As for your problem have you tried CTRL ALT DELETE after all it's all computer controlled .
    Stu
    Tool's ? check ! Condom's ? check !
    Aug 2009
    New Zealand
    2,554
    26
    It certainly sounds like you got to many strings in the system. your solar array aint working, other wise you would know that your discharge temp would be close to 370K, so unfortunately you only have a hydralic pump system with a bit vapor drawn through your jet compressor. Do you not think that the excess load comes from you rooting the on board sheep, Do you think it just coincidental about the sun, you have to see what you are doing "which end to stick it in)
    Oct 2008
    newbury
    1,444
    37
    Are you qualified to work on refrigeration systems?
    (come on guy's what would you expect me to say :-)
    Oct 2001
    Nottingham UK
    5,668
    MOB for sure......lol
  19. #19
    Sep 2011
    NZ
    AHA!
    Hi Monkey
    our magneto realignment led is constantly flashing when we are in the upper orbit and the compressor gets rather noisy plus we have found it is accerating to twice its design spec, when suction is low, how can we correct the pull of the earth, we have also had our neutrino metre go off the scale, so this could also still be an issue, your thoughts? thankyou
    Quote Originally Posted by al View Post
    OP
    al
    al
    could kill for a smoke
    Quote Originally Posted by stufus View Post
    Hey AussieIce
    Stu
    I did lots of parts spreading out everywhere, but looked like most of the Gold is falling over Cork and Nottingham
    Quote Originally Posted by mad fridgie View Post
    The mad proffessor designer of the widget arrives, we need more nutty proffessors at NASA, could you spare us some time oh wise one?
    Quote Originally Posted by r.bartlett View Post
    Can you send me a manual if I show you my Certs?
    No I am not from South Africa
    I can let on I am a big fan of the Rams
  20. #20
    ireland
    1,450
    41
    Sorry astro man, was missing the link:
    http://bit.ly/cXlekv
    ah, happiness is...
    al
  21. #21
    Sep 2011
    NZ
    Babylon Zoo is a favourite of mine http://www.youtube.com/watch?v=t_9MI2ymN6s
  22. #22
    Oct 2007
    manchester
    5,639
    45
    did u install it??? is it piped correctly!!is there an expansion line on it and are the compression ratio's correct for ur jet compressor??roger ram jet??haha
  23. #23
    3,856
    Hi Aussie,
    I think you'll find this link very helpful, it covers many of the issues you have reported,
    http://www.youtube.com/watch?v=Ac7G7...eature=related
    Monkey
  24. #24
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    C'mon fellas!!! This guy doesn't know suction from discharge pressures..
  25. #25
    Dec 2010
    Toronto, Canada
    1,454
    Hi Frank,
    Watcha drinking....certainly not the verrialian goom juice the OP needs to keep the vogon constructor fleets from knocking your house down?
  26. #26
    Aug 2008
    Auckland
    55
    259
    21
    Black Bear hunting season again?
  27. #27
    Dec 2010
    Toronto, Canada
    1,454
    Quote Originally Posted by Goober View Post
    Referring to the prof? Haven't heard from his majesty for quite a while
  28. #28
    Oct 2007
    manchester
    5,639
    45
    glad i didnt send u a manual-weve not had an update-1 post wonder!!! haha
  29. #29
    Apr 2010
    295
    15
    shot of gas init might help
  30. #30
    Oct 2007
    manchester
    5,639
    45
    bet he left his gauges in his van-and its parked 8ooo miles away!!!!haha
  31. #31
    Apr 2010
    295
    15
    well i hope he didnt step outside for a smoke its cold in space lol supprised chillerman not commented or at least fixed it for him
  32. #32
    Oct 2007
    manchester
    5,639
    45
    the question wasnt complex enough and it wasnt painted green! and it didnt have a millenium controller!!haha
  33. #33
    Dec 2010
    Toronto, Canada
    1,454
    blowed up like a big balloon......go boom
  34. #34
    Sep 2011
    NZ
    Quote Originally Posted by install monkey View Post
    Install it !
    We only install spy equipment and can view straight through your living room window
    Leave it alone it will fall off
    Who is Roger, I am Nilocm
  35. #35
    Oct 2007
    manchester
    5,639
    45
    is that why we dont have peeping toms any more- now they do it via a mickey mouse satellite with a webcam- nilocm is that one of the tweenies - u need to message tinky winky coz ur f*****g lala haha
    Install it !
  36. #36
    Apr 2010
    295
    15
    millenium controller ? green ? eh ? pretty complex question though lol
  37. #37
    Oct 2007
    manchester
    5,639
    45
    good evening aussie ice
    lets see if we can diagnose this for you
    All the readings need to be taken manualy and not off the controller
    Need to know what refrigerant first ?
    Then allow chilled water temperature to rise enough to call for compressor to run at full load 100%
    Now at full load (no saturated temperatures - actual real temperatures)
    List the answers to these conditions below
    Water or space medium cooled condensor
    If air cooled - air on & air off
    If water cooled - water in & water out
    Ambient temperature
    Discharge pressure
    Discharge temperature
    Condensor outlet temperature
    Liquid line temperature (after the drier)
    Suction pressure
    Suction temperature
    Evaporator temps/pressure taken through binda point
    Water in
    Water out
    Water return pressure
    Water flow pressure
    widget speed
    what colour carpet
    your qualifications inc references
    favourite position
    basic salary
    hours actually worked
    charity work
    space travel rate
    approximate locations,altitude and freq of orbit cycles
  38. #38
    Sep 2011
    NZ
    Hi Aussie,
    Monkey
    You may have stumbled upon some of our problems here. Our inverse reactive current keeps somersaulting, with the turbo encabulator loosing power from motion and the fluxs are causing resistance, are there any alternatives to abolish this flux resistance. It would also appear we are suffering magneto reluctance being so close to earth, which also causes our panemetric fans to oscilate out of control intermittently. Which in turn now causes our craft to have a side fumbling affect, so we stripped it down this week and found two girdle springs are bent and one is broken. As you appear to be up to lightspeed with all this monkey, do carry out orbiting service calls my friend ?
  39. #39
    Sep 2011
    NZ
    Quote Originally Posted by mikeref View Post
    I can differentiate between pushing and pulling
  40. #40
    Oct 2007
    manchester
    5,639
    45
    Water or Air cooled condensor
    Ambient temperature
    Discharge pressure
    Suction pressure
    Suction temperature
    Water in
    Water out
    Water flow pressure
  41. #41
    Sep 2011
    NZ
    Quote Originally Posted by MikeHolm View Post
    Hi Frank,
    Holm, yes that name rings a bell, a good looking womaniser always having a free feel of our fellow lady cosmosnauts, so we made a few minor adjustments to his wedding tackle, by placing them outside the capsule for a few seconds did the trick, they now have a multi-coloured black and red appearance and have shrunk to a fraction of there original size, and between us friends I can whisper there was not much to shrink in the first place!
  42. #42
    Sep 2011
    NZ
    Quote Originally Posted by simon@parker View Post
    A drop of NOS would not go a miss in our fresh air make up system
  43. #43
    Sep 2011
    NZ
    Yes I am surprised also that fraction man has not tried to have a crack at this as he does with most things he does not understand
  44. #44
    Oct 2007
    manchester
    5,639
    45
    maybe your operating system has gremlins-u may need to defrag ur harddrive and reinstall and add virus protection,frank might have an old copy from a few years ago!
    rrr monkey!!!haha
  45. #45
    Sep 2011
    NZ
    Ambient temperature
    Discharge pressure
    Suction pressure
    Suction temperature
    Water in
    Water out
    Water flow pressure
    widget speed
    what colour carpet
    favourite position
    basic salary
    charity work
    space travel rate
    Thats a lot of questions that dont appear to have any relevance to our equipment, it was a blo*dy installer that got us in this mess rodney, so we dont need your help thankyou, move along now [hand gesture]
  46. #46
    Sep 2011
    NZ
    rrr monkey!!!haha
    This Frank keeps cropping up. Who is he? He the man in charge down here?
  47. #47
    Apr 2010
    295
    15
    best guy i can point ya 2 to solve yr prob is chillerman 2006 he is top monkey at this kind of bollox will blow yr mind with tech stuff cant understand why he not jumped on this thread will prob wait for it to hit 350 comments for all the info to be there myself making an educated guess on this only if you look at wall in front of controller and then at controller am thinkin yr prob lies in between the two just a guess though that lol
  48. #48
    Sep 2011
    NZ
    Surely you can recommend some with a bit more knowledge than fraction man, we need help from someone that knows what they are talking about, not guess from a trainee, I presume a trainee with such little knowledge. Maybe the widget inventor will return or your very own in house jedi master, the tall one in the photo
  49. #49
    Apr 2006
    55
    1,908
    30
    Oit SpaceCadet
    who you calling fraction man
    thats 'Sir' to you boy
    No fook*ng R's from chillerman
    Gents who is this clown ? Have missed this one
    If the World did not Suck, We would all fall off !
  50. #50
    Apr 2006
    55
    1,908
    30
    Ambient temperature
    Discharge pressure
    Suction pressure
    Suction temperature
    Water in
    Water out
    Water flow pressure
    Haha
    You copying and doctor who-ing my posts Install
    R's chillerman
