Results 1 to 18 of 18
Thread: Whats This ?
24-09-2011, 09:17 PM #1
Whats This ?
Evening Gents
Doing my usual browsing came across the attached
Can 'Anyone' give an in depth explanation of what this is ?
R's chillerman
If the World did not Suck, We would all fall off !
24-09-2011, 09:24 PM #2
Re: Whats This ?
Some sort of co- gen plant , CHP or similar.??
But if your after specific's ,well then best wait for another reply
Stu
By the way the top right of the image is cropped so I can't stand over my guess..Tool's ? check ! Condom's ? check !
24-09-2011, 09:33 PM #3
Re: Whats This ?
24-09-2011, 09:37 PM #4
24-09-2011, 09:41 PM #5
Re: Whats This ?
Argh ! we dont that for sure, until the 'mad fridgie' arrives & decides increased mass flow/velocity could improve
heat transfer....and not knowing how it works...I have not got a 'scooby doo' yet !
Hopefully can learn some from this application, if someone would be kind enough to explain
how it works
R's chillermanIf the World did not Suck, We would all fall off !
24-09-2011, 09:49 PM #6
24-09-2011, 09:49 PM #7
Re: Whats This ?
Here's the Patent fooked if im reading it on a saturday night.
http://www.google.com/patents?hl=en&lr=&vid=USPAT5081845&id=tFghAAAAEBAJ&oi=fnd&dq=integrated+gasification+combined+cycle& printsec=abstract#v=onepage&q&f=false
Enjoy you bleeding nerd.HAHA
24-09-2011, 09:56 PM #8
Re: Whats This ?
Well apart from you 'Install' the only other I know who would definately know exactly how this works would be 'chef' (the nuclear physicist) if he would be kind enough to grace us with his presence, but we have a lot of others here who may be able to explain this
Think I will drop 'chef' a email and see if he is available if no results this week
24-09-2011, 10:03 PM #9
Re: Whats This ?
24-09-2011, 10:07 PM #10
Re: Whats This ?
So, you get your head around your puppy????
TUT TUT
24-09-2011, 10:08 PM #11
24-09-2011, 10:43 PM #12
Re: Whats This ?
Yeah Yeah, I wonder why you gents have beasty on the Brain ?
Right getting back to IGCC, its just a bit of heat/energy/power
Us fridgies can figure this out surely ??
Will view the pic and Stu's link & see if I can start us off
Then we can fill the gaps, Yeah ??
24-09-2011, 11:15 PM #13
Re: Whats This ?
Its a coal gas electrical generation plant.
24-09-2011, 11:20 PM #14
Re: Whats This ?
Good Evening Mad
Right well we have two Generator out puts here
Steam driven, which seems to be the obvious/simple part
Which is fed by a heat recovery steam Generator
Which has been fed a mixture of steam & water
Nitrogen is also fed into the larger Gen turbine (why ???)
Carbon dioxide & water is the waste product of the smaller Generators turbine
Which then appears that water is condensed and C02 needs capturing (SES Utah’s project maybe ???)
If any of this is correct, lets rewind to ‘the rod mill’
What is this ??? How does this work ???
Also what’s going on with the main ‘30mw compressor’ & ‘cold box’
How/Why is this separating oxygen/nitrogen ???
Is the neat oxygen required as the ‘gasifier’ is the burning heat source (increase combustion) ???
What is ‘syngas’ ??? & whats the difference between ‘raw syngas’ & ‘clean syngas’ ???
Sorry mate....big list of questions
R’s chillermanIf the World did not Suck, We would all fall off !
24-09-2011, 11:34 PM #15
Re: Whats This ?
found this
Integrated gasification combined cycle
From Wikipedia, the free encyclopedia
An integrated gasification combined cycle (IGCC) is a technology that turns coal into gas—synthesis gas (syngas). It then removes impurities from the coal gas before it is combusted and attempts to turn any pollutants into re-usable byproducts. This results in lower emissions of sulfur dioxide, particulates, and mercury. Excess heat from the primary combustion and generation is then passed to a steam cycle, similarly to a combined cycle gas turbine. This then also results in improved efficiency compared to conventional pulverized coal.
[edit]Significance
Both because it can be found in abundance in America and many other countries and because the price of it has remained relatively constant in recent years, coal is used for about 50 percent of U.S. electricity needs.[1] Thus the lower emissions that IGCC technology allows may be important in the future as emission regulations tighten due to growing concern for the impacts of pollutants on the environment and the globe.[1]
[edit]Operations
Below is a schematic flow diagram of an IGCC plant:
The gasification process can produce syngas from high-sulfur coal, heavy petroleum residues and biomass.
The plant is called integrated because its syngas is produced in a gasification unit in the plant which has been optimized for the plant's combined cycle. In this example the syngas produced is used as fuel in a gas turbine which produces electrical power. To improve the overall process efficiency heat is recovered from both the gasification process and also the gas turbine exhaust in 'Waste Heat Boilers' producing steam. This steam is then used in steam turbines to produce additional electrical power.
[edit]Installations
In 2007 there were only two IGCC plants generating power in the U.S.;[citation needed] however, several new IGCC plants are expected to come online in the U.S. in the 2012-2020 time frame. The DOE Clean Coal Demonstration Project helped construct 3 IGCC plants: Wabash River Power Station in West Terre Haute, Indiana, Polk Power Station in Tampa, Florida (online 1996), and Pinon Pine inReno, Nevada. In the Reno demonstration project, researchers found that then-current IGCC technology would not work more than 300 feet (100m) above sea level.[2] The DOE report in reference 3 however makes no mention of any altitude effect, and most of the problems were associated with the solid waste extraction system. The plant failed.[3]
Poland's Kędzierzyn will soon host a Zero-Emission Power & Chemical Plant that combines coal gasification technology with Carbon Capture & Storage (CCS). The supplement of up to 10% biomass in the combustion process will make this plant even more environmentally-friendly.
The first generation of IGCC plants polluted less than contemporary coal-based technology, but also polluted water; for example, the Wabash River Plant was out of compliance with its water permit during 1998–2001[4] because it emitted arsenic, selenium and cyanide. The Wabash River Generating Station is now wholly owned and operated by the Wabash River Power Association.
IGCC is now touted as capture ready and could potentially capture and store carbon dioxide.[5] (See FutureGen)
There are several advantages and disadvantages when compared to conventional post combustion carbon capture and various variations and these are fully discussed at reference 6.[6]
[edit]Cost and reliability
The main problem for IGCC is its extremely high capital cost, upwards of $3,593/kW.[7] Official US government figures give more optimistic estimates [8] of $1,491/kW installed capacity (2005 dollars) v. $1,290 for a conventional clean coal facility, but in light of current applications, these cost estimates have been demonstrated to be incorrect.[citation needed]
Outdated per megawatt-hour cost of an IGCC plant vs a pulverized coal plant coming online in 2010 would be $56 vs $52, and it is claimed that IGCC becomes even more attractive when you include the costs of carbon capture and sequestration, IGCC becoming $79 per megawatt-hour vs. $95 per megawatt-hour for pulverized coal.[9] Recent testimony in regulatory proceedings show the cost of IGCC to be twice that predicted by Goddell, from $96 to 104/MWhr.[10][11] That's before addition of carbon capture and sequestration (sequestration has been a mature technology at both Weyburn in the US (for enhanced oil recovery) and Sleipner in the North Sea at a commercial scale for the past ten years)—capture at a 90% rate is expected to have a $30/MWh additional cost.[12]
Wabash River was down repeatedly for long stretches due to gasifier problems. The gasifier problems have not been remedied—subsequent projects, such as Excelsior's Mesaba Project, have a third gasifier and train built in. However, the past year has seen Wabash River running reliably, with availability comparable to or better than other technologies.
The Polk County IGCC has design problems. First, the project was initially shut down because of corrosion in the slurry pipeline that fed slurried coal from the rail cars into the gasifier. A new coating for the pipe was developed. Second, the thermocoupler was replaced in less than two years; an indication that the gasifier had problems with a variety of feedstocks; from bituminous to sub-bituminous coal. The gasifier was designed to also handle lower rank lignites. Third, unplanned down time on the gasifier because of refractory liner problems, and those problems were expensive to repair. The gasifier was originally designed in Italy to be half the size of what was built at Polk. Newer ceramic materials may assist in improving gasifier performance and longevity. Understanding the operating problems of the current IGCC plant is necessary to improve the design for the IGCC plant of the future. (Polk IGCC Power Plant, http://www.clean-energy.us/projects/polk_florida.html.) Keim, K., 2009, IGCC A Project on Sustainability Management Systmes for Plant Re-Design and Re-Image. This is an unpublished paper from Harvard University)
General Electric is currently designing an IGCC model plant that should introduce greater reliability. GE's model features advanced turbines optimized for the coal syngas. Eastman's industrial gasification plant in Kingsport, TN uses a GE Energy solid-fed gasifier. Eastman, a fortune 500 company, built the facility in 1983 without any state or federal subsidies and turns a profit.[13][14]
There are several refinery-based IGCC plants in Europe that have demonstrated good availability (90-95%) after initial shakedown periods. Several factors help this performance:
- None of these facilities use advanced technology (F type) gas turbines.
- All refinery-based plants use refinery residues, rather than coal, as the feedstock. This eliminates coal handling and coal preparation equipment and its problems. Also, there is a much lower level of ash produced in the gasifier, which reduces cleanup and downtime in its gas cooling and cleaning stages.
- These non-utility plants have recognized the need to treat the gasification system as an up-front chemical processing plant, and have reorganized their operating staff accordingly.
A new generation of IGCC-based coal-fired power plants has been proposed, although none is yet under construction. Projects are being developed by AEP, Duke Energy, and Southern Company in the US, and in Europe by ZAK/PKE, Centrica (UK), E.ON and RWE (both Germany) and NUON (Netherlands). In Minnesota, the state's Dept. of Commerce analysis found IGCC to have the highest cost, with an emissions profile not significantly better than pulverized coal. In Delaware, the Delmarva and state consultant analysis had essentially the same results.
The high cost of IGCC is the biggest obstacle to its integration in the power market; however, most energy executives recognize that carbon regulation is coming soon. Bills requiring carbon reduction are being proposed again both the House and the Senate, and with the Democratic majority it seems likely that with the next President there will be a greater push for carbon regulation. The Supreme Court decision requiring the EPA to regulate carbon (Commonwealth of Massachusetts et al. v. Environmental Protection Agency et al.)[16] also speaks to the likelihood of future carbon regulations coming sooner, rather than later. With carbon capture, the cost of electricity from an IGCC plant would increase approximately 30%. For a natural gas CC, the increase is approximately 33%. For a pulverized coal plant, the increase is approximately 68%. This potential for less expensive carbon capture makes IGCC an attractive choice for keeping low cost coal an available fuel source in a carbon constrained world.
In Japan, electric power companies, in conjunction with Mitsubishi Heavy Industries has been operating a 200 t/d IGCC pilot plant since the early '90s. In September 2007, they started up a 250 MW demo plant in Nakoso. It runs on air-blown (not oxygen) dry feed coal only. It burns PRB coal with an unburned carbon content ratio of <0.1% and no detected leaching of trace elements. It employs not only F type turbines but G type as well. (see gasification.org link below)
Next generation IGCC plants with CO2 capture technology will be expected to have higher thermal efficiency and to hold the cost down because of simplified systems compared to conventional IGCC. The main feature is that instead of using oxygen and nitrogen to gasify coal, they use oxygen and CO2. The main advantage is that it is possible to improve the performance of cold gas efficiency and to reduce the unburned carbon (char).
With a 1300 degrees C class gas turbine it is possible to achieve 42% net thermal efficiency, rising to 45% with a 1500 degree class gas turbine, with CO2 capture. In case of conventional IGCC systems, it is only possible to achieve just over 30% efficiency with a 1300 degree gas turbine.[citation needed]
The CO2 extracted from gas turbine exhaust gas is utilized in this system. Using a closed gas turbine system capable of capturing the CO2 by direct compression and liquefication obviates the need for a separation and capture system.[17]
[edit]IGCC Emission Controversy
In 2007, the New York State Attorney General's office demanded full disclosure of "financial risks from greenhouse gases" to the shareholders of electric power companies proposing the development of IGCC coal-fired power plants. "Any one of the several new or likely regulatory initiatives for CO2 emissions from power plants - including state carbon controls, EPA's regulations under the Clean Air Act, or the enactment of federal global warming legislation - would add a significant cost to carbon-intensive coal generation";[18] U.S. Senator Hillary Clinton from New York has proposed that this full risk disclosure be required of all publicly-traded power companies nationwide.[19] This honest disclosure has begun to reduce investor interest in all types of existing-technology coal-fired power plant development, including IGCC.
Senator Harry Reid (Majority Leader of the 2007/2008 U.S. Senate) told the 2007 Clean Energy Summit that he will do everything he can to stop construction of proposed new IGCC coal-fired electric power plants in Nevada. Reid wants Nevada utility companies to invest in solar energy, wind energy and geothermal energy instead of coal technologies. Reid stated that global warming is a reality, and just one proposed coal-fired plant would contribute to it by burning seven million tons of coal a year. The long-term healthcare costs would be far too high, he claimed (no source attributed). "I'm going to do everything I can to stop these plants.", he said. "There is no clean coal technology. There is cleaner coal technology, but there is no clean coal technology."[20]
One of the most efficient ways to treat the H2S gas from a IGCC plant, is by converting it into sulphuric acid in a wet gas sulphuric acid process wsa process
[edit]See also
[edit]References- ^ a b Schon, Samuel C., and Arthur A. Small III. "Climate change and the potential of coal gasification." Geotimes 51.9 (Sept 2006): 20(4). Expanded Academic ASAP. Gale. University of Washington. 28 Oct. 2008 |date=October 29, 2008
- ^ Source: Joe Lucas, Executive Director of Americans for Balanced Energy Choices, as interviewed on NPR's Science Friday, Friday May 12, 2006
- ^ Information Bridge: DOE Scientific and Technical Information - Sponsored by OSTI
- ^ Wabash River Energy Ltd. (August 2000). "Wabash River Coal Gasification Repowering Project Final Technical Report" (PDF). Work performed under Cooperative Agreement DE-FC21-92MC29310. The U.S. Department of Energy / Office of Fossil Energy / National Energy Technology Laboratory / Morgantown, West Virginia. Retrieved 2008-06-30. "As a result, process waste water arising from use of the current feedstock, remains out of permit compliance due to elevated levels of arsenic, selenium and cyanide. To rectify these concerns, plant personnel have been working on several potential equipment modifications and treatment alternatives to bring the discharge back into compliance. Wabash River is currently obligated to resolve this issue by September 2001. [p. ES-6] Elevated levels of selenium, cyanide and arsenic in the waste water have caused the process waste water to be out of permit compliance. Daily maximum values, though not indicated in the table above, were routinely exceeded for selenium and cyanide, and only occasionally for arsenic. [p. 6-14, Table 6.1L]"
- ^ http://www.gepower.com/prod_serv/pro.../app_power.htm
- ^ http://www.claverton-energy.com/inte...e-storage.html Claverton Energy Group conference 24th October Bath.
- ^ Excelsior's Mesaba Project
- ^ http://www.eia.doe.gov/oiaf/aeo/assu...ity.pdf#page=3
- ^ Goodell, Jeff. "Big Coal." pg. 214. New York, Houghton Mifflin. 2006
- ^ Testimony of Dr. Elion Amit, Minnesota Dept. of Commerce.
- ^ http://www.mncoalgasplant.com/puc/05...20rebuttal.pdf.
- ^ http://www.newenergymatters.com/?p=l...sort=2&id=1766
- ^ Goodell, Jeff. "Big Coal." New York, Houghton Mifflin. 2006
- ^ Eastman - Eastman Chemical Company - Home Page
- ^ http://www.nuon.com/about-nuon/Innov...cts/magnum.jsp
- ^ Massachusetts, et al. v. Environmental Protection Agency, 05-1120 - FindLaw US Supreme Court Center
- ^ Inumaru,Jun - senior research scientist, Central Research Institute of Electric Power Industry (CRIEPI)(Japan) G8 Energy Ministerial Meeting Symposium, Nikkei Weekly.
- ^ http://www.marketwire.com/mw/rel_us_print.jsp?id=776699
- ^ http://www.hillaryclinton.com/files/...icasfuture.pdf
- ^ http://publicutilities.utah.gov/news...pposescoal.pdf
- Hunstown: Ireland's most efficient power plant @ Siemens Power Generation website
- Natural Gas Combined-cycle Gas Turbine Power Plants Northwest Power Planning Council, New Resource Characterization for the Fifth Power Plan, August 2002
- Combined cycle solar power
Rate this page
What's this?
Trustworthy
Objective
Complete
Well-written
I am highly knowledgeable about this topic (optional)
Submit ratings
Categories: Thermodynamic cycles | Chemical engineering | Power station technology | Energy conversion
Interaction
Toolbox
Print/export
Languages
- This page was last modified on 3 August 2011 at 23:17.
- Text is available under the Creative Commons Attribution-ShareAlike License; additional terms may apply. See Terms of use for details.
Wikipedia® is a registered trademark of the Wikimedia Foundation, Inc., a non-profit organization. - Contact us
24-09-2011, 11:42 PM #16
Re: Whats This ?
Hi Install
Thanks for the two lines that answered the 'syngas' question
can you answer any more for me mate, without all the irrelevants to the questions
of how does it work ???
24-09-2011, 11:47 PM #17
Re: Whats This ?
24-09-2011, 11:55 PM #18
Re: Whats This ?
