Results 1 to 15 of 15
    Short Filling of New Refrigerant Bottles
    Does anyone else suffer from being short changed on refrigerant by the bottle fillers?
    Two of the last cylinders that I bought from Climate Center, who use A-Gas, were sold as containing 11kgs of R410a.
    However, when weighed before use I found that one contained about 9kgs and the other 8.6kgs.
    Obviously CC sell on the A-Gas product without checking the bottles but considering the price of refrigerant now is it not time to start writing to your supplier to stop what amounts basically to theft.
    70
    4,700
    47
    Re: Short Filling of New Refrigerant Bottles
    I agree, have had more than a few in the past and let it slide.
    Now that you mention it Brian.
    I may raise the issue next time.
    Jun 2009
    North East England
    712
    Never noticed on new cyliders, but have noticed the dip tubes in receiver cylinders are cut short quite often, which is a pain on large bottles
    Apr 2006
    55
    1,908
    30
    Hi Brian
    have never had it that far out, but have noticed most of the time it ranges from 10.5-11.5 & has normally evened itself out
    if we all start complaining and where time is available either check bottles when collected/delivered and back the ones that are low...it should not take long to rectify itself
    will inform everyone I know in trade today
    R's chillerman
    Apr 2010
    295
    have always checked bottle weight its best to wheealed as well as theres no way you can prove it and i do believe it leaks out its not short weight its lost gas but who leak tests there bottles ? or even checks them for leaks when they come
    I can fix broke but I cant fix stupid :)
    Good point Simon, I'll have to start checking that.
    I have told CC that we will be writing to them about it, what happens is another matter.
    But when you consider our legal responsibilities (let's not start off on this one yet) how do you 'account' for that one kilo of gas that wasn't there in the first place?
    Also how can you charge your client for 11 kgs of gas when you've only put 8.5?
    ireland
    1,451
    Why don't you weigh the bottles at purchase? Not beyond the wholesalers to hook up scales, seeing as how they have to make up the shortfall to you.
    al
    Apr 2006
    55
    1,908
    30
    Quote Originally Posted by al View Post
    al
    Good point Al
    for most buying across counter anyway
    my refrigerant is delivered to site & first I see of it could be days after delivery
    And I do not have the means of transporting a number of bottles back to supplier
    This is something that needs rectifieing at source, the manufacturers
    as they now have an obligation under f-gas (I think - is that correct ???)
    R's chillerman
    3,853
    Had a R22 bottle that was 200g short the other day, i keep the caps on them when not using them so wonder if it was a short fill rather than leakage in storage.
    The other thing i notice is the tare weight doesn't always tally with whats stamped on the bottle....
    I will be paying more attention to this in future.
    On a similar theme, have had acetylene and oxygen bottles that have been only half pressure on first use too, and at the prices boc charge i think i will be making more of a fuss over this to rather than just letting things go.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Quote Originally Posted by simon@parker View Post
    Simon, just so you know, it is law here in Australia to check all refrigerant bottles on a regular basis for leaks. Has to be written down and kept on file for audit purposes. The list goes on but haven't found A-Gas to short change me.. yet. Always check new oxy/acet bottles as one i picked up was 1/2 empty.
    Mar 2011
    Australia
    43
    67
    14
    I check the net refrigerant amount every pick up and have found the odd one short of gas. In Australia my employer uses the refrigernt records required by the ARC every 3 months along with purchase order records and job sheets to moniture how much refrigerant I have purchased and how much I have billed to the customer. If I get a bottle short a couple KG it will show up missing in the records and will result in an arguement with my employer.
    Oct 2008
    newbury
    1,444
    I have mentioned this several times over the last few years.This being only recently:
    http://www.refrigeration-engineer.co...049#post241049
    Also pipe and cable manufacturers short changing..It's common in manufacturing...
    Apr 2006
    55
    1,908
    30
    Just Viewed, hmmm see this been happening for some time then
    EVERYONE has to complain & return goods....only way to get it sorted
    bet they just palm it off to someone else though
    to much agro to return to manufacturers
    R's chillerman
    Apr 2010
    295
    way to make sure yr audit always stands up is every gas bottle gets its own piece of paper that stays with it you write on it date you got bottle and the recieved weight you write on every unit you use it on and how much you put in if you use it all on only one unit you still do the piece of paper when bottle empty you weigh it write that on paper and return it a full auditable system oh also put bottle serial number on it as well can be used for reclaim cylinders as well also handy cos u instantly know how much gas you got in bottle or space to relaim to i implimented this at my current employers it works an it works well we have a full trail from birth to return for every single bottle of gas with its serial no on and the mod serial no of unit and site unit on fully Fgas compliant also you know when a bottle comes and its short of gas still sealed
    Mar 2006
    belfast
    239
    a gas bottles are bad for leaking, ive had a few returned due to this
