Results 1 to 13 of 13
Thread: Hotpoint FFA40X no power
16-09-2011, 10:32 PM #1
Hi all,
I have a hotpoint FFA40X fridge freezer from Hotpoint. it used to give the bleeping noise with flashing lights every now and then when we left the door open overnight by mistake..
recently it happened again, as usual we switched it off for a while and back on again but it didnt fix. I asked my girl friend to empty it out and let it defrost for few days. left it off two days and now when we plug it in, the thing doesnt even show any power...
any advice will be helpful guys.. please advise where should I start from?
thanks
16-09-2011, 10:54 PM #2
Re: Hotpoint FFA40X no power
well would try fuse first an go from there
I can fix broke but I cant fix stupid :)
16-09-2011, 11:14 PM #3
Lol.. wish it was the fuse... It was the first thing i checked.. cheers
16-09-2011, 11:29 PM #4
any electrical experiance ? if you dont i would leave it and either get a quote from a pro or buy new fridge prob cost the same in end
16-09-2011, 11:31 PM #5
is there a wiring diagram on the back of it? theres probably a 20mm glass fuse protecting the pcb
16-09-2011, 11:45 PM #6
Install Monkey, I have attached the wiring diagram.. Im hopeless reading the wiring diagram although confident to fix it myself..
so far I have looked into the Overload (attached to the compressor) and visually found some fine netal sort of shavings on plastic cover.. will look further once my brother has dropped off my multi meter he borrowed..
I see the thermal fuse on the diagram but dont know where its located.. do you think its located on PCB on the very top where the buttons are?
please advise.. really appreciate your helps guys..
16-09-2011, 11:55 PM #7
thermal fuses are small overheat stats that reset at a predetermined temp theyll be located on the evap coil inside-it wont be them.
is there power at the socket? plug a table lamp in to prove this
does the light work when the door is open? if so theres power,inspect the pcb visually for a fuse or charring .
is there a fast freeze option-this bypasses the thermistor and will run continuosly
17-09-2011, 12:09 AM #8
mate, this is very useful..
I have found the PCB and visually can see the damage... but dont know whether I should replace the PCB or whats damaged on it..
pic attached - can see R13 damaged.. R5 damaged.. C1 also looks damaged
17-09-2011, 07:46 AM #9
send ur pcb off to these guys they will test and repair it if needed
http://qer.biz/servReps.htm
17-09-2011, 11:30 AM #10
Frigidare, dry solder join will cause this. So many problems with soft solder on mass produced P.C. boards.
17-09-2011, 02:12 PM #11
17-09-2011, 06:58 PM #12
it could be just heat rejected off the resistor, inspect the back of the pcb to see if there are any cracks in the solder.
you still need to test power to the pcb and power out off the relay
17-09-2011, 08:06 PM #13
if you are struggling go on ebay you can buy new parts for alot of white goods on there price isnt to bad either
